Anecdotes 2
Anecdotes 2
Home › Forums › General Questions › Anecdotes 2
Viewing 25 posts - 1 through 25 (of 35 total)
  • #109128
    MICHAEL WILLIAMS
      @michaelwilliams41215
      There is always discussion of limits , fits and accuracy on this site so a I thought that I'd tell you about one or two oddball examples that have appeared correctly on real parts drawings .
      (1) On a modest size and quite simple steel component :
      Radius of 6000 inches +/- 200 inches
      What do you think the part was and why such an odd dimension and tolerance ???
      #22420
      MICHAEL WILLIAMS
        #109131
        Ed Duffner
          @edduffner79357
          Peco Setrack 1:1 scale?
          or part of the Hadron Collider?
          #109136
            I sould think the decimal points were missing maybe it should be 6.000" +- 0.002"
            #109137
            Durhambuilder
              @durhambuilder
              Hmm, doesn't necessarily need to be a complete circle, it could be a short arc?
              #109140
              Martin W
                @martinw
                How about something like plates for a large fuel storage tank or a piece of railway track. Where they will finalise the diameter/radius on site by pulling into final shape.
                #109141
                Sub Mandrel
                  @submandrel
                  Something like a point frog? 500 feet +/- quite a lot sounds like the spec for full size rail radius.
                  MICHAEL WILLIAMS
                    Its a dimension and tolerance which appears on a drawing of an aeroengine component .
                    Less sophisticated examples of the same component can be found in more commonplace engines .
                    #109182
                    jason udall
                      @jasonudall57142
                      Moderate sized….?say 12"long .so approx 2 milli radians 0.1 degree or 6 minutes……or somthing like 3 thou on 6 "(3 thou each end of 12&quot..difference of straight line and arc segment….
                      I have programmed such radii to compensate for "barrel"shapes in journals…
                      6000+/-200…seems a realistic Toll…in percentage terms…
                      I have had (automotive production) drawings such that a drawn feature may disapear if other dimensions are at the extreem of their tolerence…(think three lengths ….over all. and two lengths in from opposing ends)….
                      I sometimes wonder if anyone reads these before issue.
                      #109184
                      _Paul_
                        @_paul_
                        Modest size, simple & part of an aero engine….. could it be the curvature of a rocker arm? or perhaps the prop boss?
                        #109190
                        MICHAEL WILLIAMS
                          Hi Jason ,
                          Close enough !
                          The pins and journals on some Bristol radials were crowned to reduce local stresses .
                          6000 inches +/- 200 inches was a typical value .
                          Don't know what the good component yield percentage was in manufacture but they would certainly have been inspected and approved/rejected individually .
                          Regards ,
                          Michael Williams
                          Edited By MICHAEL WILLIAMS on 19/01/2013 09:19:32
                          #109191
                          Stovepipe
                            @stovepipe
                            Looking at Argos website yesterday – a "Dremel" accessory set, weight 450 KG. Blimey, some accessory !
                            Dennis
                            #109236
                            Ed Duffner
                              @edduffner79357
                              Posted by MICHAEL WILLIAMS on 19/01/2013 09:11:47:
                              Hi Jason ,
                              Close enough !
                              Regards ,
                              Michael Williams
                              But how would you go about checking this tolerance? Isn't it more sensible to reduce the figures to workable/measurable values?
                              #109426
                              MICHAEL WILLIAMS
                                Hi Ed ,
                                The crowning has to be of very large radius compared to the component – really its just a very slight reduction of diameter of pin (or whatever) at outer ends .
                                The 6000 inch +/- 200 inch figures appeared on engine drawings which were done in the 1930 to 1950 period .
                                Crowning is still very important on many engineering components but the means of specifying on drawings and means of manufacture have moved on considerably .
                                Regards ,
                                Michael Williams .
                                #109428
                                Phil P
                                  @philp
                                  I once had a mate who got sacked for being a thou out on one job.
                                  He worked in a bank at the time.
                                  Phil
                                  #109465
                                  jason udall
                                    @jasonudall57142
                                    Posted by MICHAEL WILLIAMS on 20/01/2013 19:14:58:
                                    Hi Ed ,
                                    Regards ,
                                    Michael Williams .
                                    It would be , "even" today be a near impossible dimention to check with linear 1D instruments..the "radius" would be Calculated from a cloud of 2D or 3D points….
                                    many features today are more difficult to measure/verify than they are to generate..(both in the DO and in the factory)……
                                    #109579
                                    Sub Mandrel
                                      @submandrel
                                      Jason – how would you actually machine such a radius – some complex geometrical too to generate the radius without having a 6000 inch bar? or would you simply lap the journal concave?
                                      jason udall
                                        @jasonudall57142
                                        How would I?
                                        Cnc if not ground.( or if less that 1000)
                                        Centerless grinder from ("parallel" ) with profiled wheels if ground finish..(or more than 1000 pcs)
                                        Diamond dresser cam / former CNC generated and verified as below…
                                        The above deals with making it..checking/inspection of 6000" radius would be the real chalenge..I would use our 2D "height" gauge and rely on mathematics to derive radius from three points…..serveral times
                                        Just how I work in the day job…
                                        #109615
                                          Hi Jason ,
                                          Close enough !
                                          Regards ,
                                          Michael Williams
                                          It would be interesting to know a little more about these components
                                          … Length, Diameter, Surface Finish …
                                          Whilst I have no historical evidence to support this; I suspect that 6000" radius +/- 200" was intended to prescribe "tramlines" within which the actual shape [including its Straightness and Surface Finish] could be whatever suited the manufacturing process.
                                          Jason's expert description shows how he would make it now; I remain intrigued by how they would have done it in the 1930s
                                          P.S.   Whilst browsing, I just found this eBook about the Packard Diesel Radial.
                                          Edited By Michael Gilligan on 22/01/2013 08:32:40
                                          #109619
                                          jason udall
                                            @jasonudall57142
                                            in 30's… either centerless or between center grinding .
                                            As to measuring it….well in production I would expect 3 "snap" mikes or dial indicators ( I have 1/10,000 " clocks in my collection…) …mounted in fixture controlling/fixing the postion along the part….. but I would be guessing…wink
                                            #109632
                                            Anonymous
                                              Hmmmm, if I've got my calculations right, and assuming the journal is 2" wide, I make that a difference of 0.000083" on the radius. In other words less than a 10th of a thou. The tolerance variation would be rather smaller.
                                              Under wartime pressures to get engines off the production line I suspect it may have been quietly ignored, plus a certain amount of muttering by machinists about draughtsmen who came up with the tolerance in the first place.
                                              #109639
                                              jason udall
                                                @jasonudall57142
                                                Posted by Andrew Johnston on 22/01/2013 11:50:06:
                                                Quite… inspection would be challenging
                                                #109641
                                                Joseph Ramon
                                                  @josephramon28170
                                                  Perhaps just hand held emery to relieve the centre would do the job.
                                                  Joey
                                                  #109736
                                                  MICHAEL WILLIAMS
                                                    Rollers in roller bearings are crowned in volume production and these are of even flatter curvature . More sophisticated methods are available now but for many years the crowning was done by tumbling .
                                                    Very flat radii on components are easy to measure optically – again there are new sophisticated methods but for many years checking was done by the fringe counting method .
                                                    Need to make a distinction between the diameter of the component as such and the crowning effect when considering measurement methods .
                                                    The original Bristol components were hand lapped . May sound hard work but it was a doddle compared to making some of the other engine parts . It may well have been that the actual dimension was just a ' guide in principle ' and that a slight fairing off of the outer ends of pin was usually in the right ball park dimensionally after a skilled worker had done a few by trial and error .
                                                    Quick and often used ' workshop ' test for crowning is to spin component on glass (barrel wise ) . If it spins freely crowning is present and probably adequate .
                                                    Other things are sometimes crowned – one example is of gear teeth for demanding applications .
                                                    Michael Williams .
                                                    Edited By MICHAEL WILLIAMS on 22/01/2013 23:32:52
                                                    #109740
                                                      Posted by MICHAEL WILLIAMS on 22/01/2013 23:27:59:
                                                      Michael Williams .
                                                      Thanks … I will remember that one!
                                                      Bound to come in useful sometime.
