An Uninvited Guest!
An Uninvited Guest!
Home › Forums › The Tea Room › An Uninvited Guest!
Viewing 25 posts - 1 through 25 (of 41 total)
  • #568316
    Swarf, Mostly!
      @swarfmostly
      Hi there, all,
      Posting these photos is inviting scorn but I hope there'll be some sympathy too.
      How do you tell when it's been too long since you had any workshop time?
      As they say 'Life happens!'.
      Identification will be welcome.
      Best regards,
      Swarf, Mostly!
      #36608
      Swarf, Mostly!
        @swarfmostly
        It’s been a warm, wet summer.
        #568321
        Nigel Bennett
          @nigelbennett69913
          Looks like ivy to me.
          #568322
          Philip Rowe
            @philiprowe13116
            It looks like an ivy to me and in all fairness it does grow very rapidly but not overnight. Seems you do need to spend some time out there if only to clear your visitor. Phil
            #568328
            Richard S2
              @richards2
              From the leaf form, it could be Hedera Hibernica?. And to alleviate your guilt complex of neglect, it is considerably fast growing.
              #568333
              Rik Shaw
                @rikshaw
                Could be black or white Bryony.
                Rik
                #568338
                DiogenesII
                  @diogenesii
                  ..or maybe even Schizophragma..
                  #568339
                  Dave Halford
                    @davehalford22513
                    Myford Strangler Vine
                    #568341
                    Sam Longley 1
                      @samlongley1
                      I have a similar problem and a small length of ivy has just found its way into the shed. Unfortunately I cannot get to the main plant as it is on the corner of the wokshop within 12 inches of the boundaries of 2 other properties. The plant is right in the corner & is quite substantial. I can only get access from the top & it has already started to damage the gutter beneath my pitched roof. My roof is cementous corrigated pitched construction & balancing is difficult on crawling boards
                      Soooo!! Has anyone any ideas what is the best method of killing it off.. . I did try pouring dieisel down over the leaves with a spray can from above & I believe that slowed the growth. However, it has come back.
                      Any ideas welcome
                      Edited By Sam Longley 1 on 26/10/2021 15:41:23
                      #568343
                      Mark Rand
                        @markrand96270
                        Probably need a greater rate of cut and a better chip breaker if the swarf is coming off like that.
                        #568348
                        pgk pgk
                          @pgkpgk17461
                          Going greener – very modern!
                          pgk
                          #568351
                          Adrian 2
                            @adrian2
                            Bamboo is another invader to avoid. I had a shoot grow up inside the studwork framing of my workshop, first I knew of it was when it hit the roof turned and pierced the insulation growing back downwards.
                            It has taken several years to get rid of but I am winning.
                            Adrian.
                            #568352
                            Howard Lewis
                              @howardlewis46836
                              Had a similar problem with the previous workshops. The problem was that the main stem was between the shop and the fence, so VERY difficult to cut off near the ground.
                              A saw blade fixed to a long pole did the trick, eventually.
                              Now the problem is one of SWMBOs plants that can cause heave depending on the weather, making the door stick sometimes. What started as a tiny stem is now nearly 100 mm diameter, but cannot be pruned other than gently.
                              Ivy seems to share some of the genes of Mile a Minute Russian Vine., and is very difficult to keep in check
                              SWMBO put some weedkiller on the grass,(Supposed to be safe for grass ) Killed the grass as well as the weed, A year on it still has not recovered, despite reseeding. This might be the stuff to put on the root, if you can dribble some down a tube into the area. "Weedol" perhaps?
                              Squirt from a water pistol may get the killer where it is needed.
                              #568354
                              Dave Halford
                                @davehalford22513
                                SBK will do it
                                #568358
                                  Posted by Dave Halford on 26/10/2021 17:47:01:
                                  SBK will do it
                                  You seem to know your weedkillers, Dave
                                  … is it any good on horsetails ?
                                  We have some growing up through a rockery which appear to have re-grown from root-fragments in the clay, and probably date back 100 years or more crying 2
                                  Brian Wood
                                    @brianwood45127
                                    Michael
                                    I regret to say horsetail is notoriously difficult to eradicate. It dates back to the age of the dinosaurs and has learned some survival tricks. Fossils are frequently found in coal measures.
                                    RHS Harlow Carr in Harrogate had it in their rockery, a very big rockery and the whole lot had to be dug up with excavators to a depth of maybe 20 feet to reach the base of the roots.
                                    Selective weedkillers do not touch it either so I fear you have few options.
                                    Best of luck Brian
                                    #568367
                                      Posted by Brian Wood on 26/10/2021 18:07:47:
                                      Michael
                                      I regret to say horsetail is notoriously difficult to eradicate. […]
                                      Thanks for the empathy, Brian
                                      Yes, I am unfortunately aware of all that … which is why I asked specifically about SBK
                                      https://www.progreen.co.uk/sbk-brushwood-killer-1l-kplus-250ml-marestail-woody-weeds/
                                      Grizzly bear
                                        @grizzlybear
                                        You give the horsetail a good thrashing before applying SBK, Roundup and/or diesel.
                                        It needs to be well bruised. Enjoying it, isn't compulsory.(The thrashing.)
                                        #568405
                                        Howard Lewis
                                          @howardlewis46836
                                          Grizzly,
                                          It is more blessed to give than to receive. Especially where this stuff is concerned
                                          #568495
                                          File Handle
                                            @filehandle
                                            Never manage to totally wipe out Horsetail. weedkillers will knock it back, as will WD40 etc after a good bruising. It does come back, but i have it under control.
                                            #568511
                                            DMB
                                              @dmb
                                              I believe that bamboo can be controlled by copious applications of seawater and paraffin guarantees death to virtually any vegetation. I once had a tree growing a thin trunk my side of my back garden wall and anoth on my neighbours side. I could foresee the eventual fate of my wall and the renter's next door would be unlikely to do anything. I dealt with both trunks by cutting to ground level and pouring a small quantity of paraffin on the stump. No regrowth after a decade or more, so can vouch for the paraffin,but be careful as I suspect it is a serious pollutant and nothing will grow if spilt in quantity on soil.
                                              #568515
                                              pgk pgk
                                                @pgkpgk17461
                                                I have dealt with some problem invaders by painting them individually with concentrated glyphosate, but I believe it’s now illegal to buy unless you have a spraying licence. Another option for vine type things is to coil them up and dump the oil into a washing up bowl of weedkiller for a goodly soak. Apparently adding wallpaper paste to the mix can help identify which strands have been treated if there's lots to do.
                                                pgk
                                                #568537
                                                Richard S2
                                                  @richards2
                                                  Another advocate of SBK. Killed off many 'a large Ivy root and tree stump. It will take a while.
                                                  Best time to treat ivy is in the dormant period over winter. I have drilled deep holes diagonally downwards near the base and filled them with 50/50 dilute SBK. plugged the holes after.
                                                  Additionally, a mixture of correct dilute strength SBK and kerosene to spray over the foliage during a dry spell.
                                                  Repeat treatment will accelerate it's demise.
                                                  #568570
                                                  duncan webster 1
                                                    @duncanwebster1
                                                    So as this has degenerated into gardening, anyone know how to get rid of oxalis (wood sorrel) in the lawn? We've tried selective weedkiller
                                                    #568586
                                                    Baz
                                                      @baz89810
                                                      My problem is bindweed, I have tried garden centre weedkillers and they don’t seem to work, anyone got any advice please.
