A bit of a puzzle on eBay
Home › Forums › Stationary engines › A bit of a puzzle on eBay
  • #542272
    Tony Martyr
      @tonymartyr14488
      I looked at the horizontal steam engine on ebay at: https://www.ebay.co.uk/itm/324500791669?hash=item4b8dc12175:g:PT0AAOSwdg1gOnBF
      I can't quite work out the auxillary steam/water system – there must be a lot of the original system missing ?
      Tony
      #3453
      Tony Martyr
        @tonymartyr14488
        #542274
        Steve Withnell
          @stevewithnell34426
          I think its just the boiler and water tank that's missing.
          Personally, I would not give it house room.
          #542284
            Yep water tank probably connected to the banjo fitting that is loose under the oil separator it can then flow through the pump and then off to the boiler or throw the valve the other way to act as a bypass. The 3-way valve may allow water to be sucked out the bottom of the separator too.
            #542285
            Mike Hurley
              @mikehurley60381
              Partially agree with Steve re just missing the boiler etc which obviously would have been a larger seperate unit – so perhaps it was just split up some time back?
              I have looked closely at the photos and feel that it is well built and original – look at the close up photo of the cross head assembly and note the oil channels underneath – a nice quality touch. The description on the site seems pretty comprehensive and it is quite an unusual engine in the complexity for a large model of this type.
              The price seems a little high, but saying that its a bit of a one-off, and as such will attract a premium.
              I for one would gladly give it house room if I had the chance. Regards
            Home › Forums › Stationary engines › Topics
