250 V 3 phase connector?
Home › Forums › General Questions › 250 V 3 phase connector?
Viewing 5 posts - 1 through 5 (of 5 total)
  • #104702
    frank brown
      @frankbrown22225
      I am in the process of building a static 3 phase convertor and would like to have the motor on a plug. The 415V 3P + earth connectors as used in industry are cheap but are huge!. The Amphenol ones are a reasonable size but cost about £50 for each half!! Anyone got any suggestions for a more acceptable alternative?
      Frank
      #22345
      frank brown
        @frankbrown22225
        #104715
        KWIL
          @kwil
          Huge they may well be, but they are built for the job and you would be well advised to use the standard proper fittings.
          #104733
          Clive Hartland
            @clivehartland94829
            Try Googling 3 Phase connectors and you will see socket and plug for about £15. 00
            single plugs about £9.00, perfectly adequate for what you want Frank.
            Clive
            #104743
            KWIL
              @kwil
              As I said standard industrial connectors!
