can anyone make me a file? 3d file
Home › Forums › 3D Printers and 3D Printing › can anyone make me a file? 3d file
  • #859067
    Ian Parkin
      @ianparkin39383
      I need a file to make a battery box cover for a motorcycle
      can anyone oblige (its a paying job)
      what do you need from me? an accurate dimensioned photo? or a drawing?IMG_0837IMG_0836
      #859072
      renardiere7
        @renardiere7
        Hi Ian,  I assume that you need a 3D file in a format for 3D printing?  It’s the sort of thing I do fairly frequently and as long as there is no screaming urgency I’d be happy to help out.
        In terms of what’s required. a full set of orthogonal photo views of the cover preferably taken from around 5ft away to reduce parallax errors.  Dimensioned sketches, major dimensions but also some detail, for example the depths of those recesses, presumably over the battery posts.
        DM me your email address if you are interested
        Alan
        #859079
        bernard towers
          @bernardtowers37738
          Depending on what its for Burlen Fuel Systems used to do them.
          #859118
          Roderick Jenkins
            @roderickjenkins93242
            Ian,  this is likely to be an iterative process with several printed protypes required before a satisfactory item is produced.  Best would be to let the designer have the old cover but, clearly, there is a risk in that if postal services are involved but other wise as detailed a sketch as can be managed, including various radii for the corners etc. Details of the base to which the cover is attached would also be useful to get the various clips correct.
            Where do you live?  Also, in what material would the final cover be produced.
            It’s the sort of thing I’d be happy to have a go at.
            Good luck with your quest.
            Rod
            #859122
            Ian Parkin
              @ianparkin39383
              Rod
              i have sent various photos and diagrams to alan above
              i was going to print it in abs
              the original is a sort of very hard rubber however my friend who needs it dropped something on his and it smashed into lots of bits
              #859143
              DC31k
                @dc31k
                A way around the risk you identify could be to pour castable silicone around the item in the photo to make a mould.
                That allows multiple identical copies to be made for drawing (possibly 3D scanning) or modelling purposes.
                The material out of which the copies are made is somewhat immaterial – certainly it does not need the properties of the final printed item. If one is lost in the post, it does not matter.
                #859144
                duncan webster 1
                  @duncanwebster1
                  If you can stick the major bits back together and fill any holes with body filler you might be able to get it laser scanned. Unfortunately I have no expertise to offer, but I’ll bet someone out there has
                  #859147
                    Just in case …. It might be worth browsing here:
                    https://www.classicbritishspares.com/products/lucas-rubber-battery-boxes
                    Gerard O’Toole
                      @gerardotoole60348
                      I have a similar battery box lid which I modified to incorporate fuses and a cut-out switch.
                      I am sure I can modify it to remove the switch and space for the fuses if it is of any use to your friend.
                      Below is an image from the stl file , it is not a photograph.
                      lid
                      #860203
                      Ian Parkin
                        @ianparkin39383
                        Here is the final print off the file that Alan kindly made me
                        it still needs a gentle sanding and matt varnishing perhaps
                        IMG_4618IMG_4619
                        #860216
                        Roderick Jenkins
                          Good Result!
