Material options for coloured washers
Home Forums Beginners questions Material options for coloured washers
  • #205498
    Nick anon
      @nickanon93441
      I've been getting some great results making specialist tools in Titanium and would like to make some coloured washers so that interchangeable threaded tip sections can be easily identified by their colour. It would be great if I could find a 6mm or so bar material, that comes in red, blue, yellow and maybe green. I've looked for a long time to try to source coloured Delrin that can be turned and drilled on the lathe. Unfortunately the only stock colours seem to be black and white.
      Does anyone have a suggestion for a strong machinable material that comes in a variety of colours and is suitable to be made in to compression washers? If so, where would you buy it from.
      Thanks in advance, cheers, Nick.
      Edited By Nick anon on 23/09/2015 19:19:13
      #7812
      Nick anon
        @nickanon93441
        #205501
        Old School
          @oldschool
          GWR fasteners do color fast stainless washers
          #205506
          David Clark 13
            @davidclark13
            Perspex or material from engravers for making name tags.
            #205507
              Corian
              #205511
              Nick anon
                @nickanon93441
                Is Corian available as bar stock suitable for lathe work? I had hoped that someone would make coloured Nylon which can be machined and won't split when compressed, just like Delrin.
                #205513
                  You can buy the corian in squares from some of the pen turning suppliers, probably have suitable acrylic too.
                  Another option would be to turn a shallow groove just in from the edge of your tool tip, fill with paint and whan dry buff the outside which will leave the paint in the groove
                  #205514
                  Roger Provins 2
                    @rogerprovins2
                    I must be misunderstanding you some how as coloured bar Delrin is easily available.
                    eBay 271957715367 for example and there's many more.
                    #205516
                    Nick anon
                      @nickanon93441
                      I think that is the best option so far Roger, many thanks. It is only available in 20mm minimum, so would need to
                      cut it in to sections to get 6mm diameter pieces. Hopefully it might be worth emailing the seller to see if they've got it in smaller sizes.
                      That's a very useful suggestion Jason, I'm definitely going to have a try to see how it turns out, cheers.
                      Thanks again, Nick.
                      #205522
                        Why not heat-colour your titanium?
                        Nick anon
                          @nickanon93441
                          Mainly durability Neil. I've noticed that heat induced colour tends to scratch easily. I would like the washers to be hard wearing so delrin type material seems ideal. I could use brass, but as I say, different colours would look brilliant and be functional for quick selection.
                          If I could home Anodise, Aluminium would probably work.
                          cheers for all the suggestions.
                          Nick.
                          #205534
                          Chris Denton
                            @chrisdenton53037
                            Titanium is easy enough to anodise, you just need a high voltage power supply.
                            Nylon and Delrin is easy enough to colour so I'd have thought someone would sell it.
                            Acrylic here, probably brittle though.
                            http://www.ema-models.co.uk/index.php/acrylic-plastic-shapes/round-rods-opaque.html
                            #205536
                              Nick
                              Looks like you will get more joy searching for Acetal instead of Delrin.
                              Edited By Michael Gilligan on 23/09/2015 23:26:10
                              #205549
                              David Clark 13
                                @davidclark13
                                Delrin is a trade name for a brand of acetal.
                                #205550
                                  Posted by David Clark 1 on 24/09/2015 08:00:46:
                                  David,
                                  Please read the page that I linked.
