ML7 Clutch
ML7 Clutch
Home Forums Beginners questions ML7 Clutch
  • #7808
    Roy James 2
      @royjames2
      Roy James 2
        @royjames2
        Hello all,
        I have the drawings for the ML7 clutch from issue 5 1991, which I would like to
        adapt to my old, (very old ML2), can someone inform me of the material used
        between the two cones ? I have been unable to access the article in question.
        james
        #205191
        Gray62
          @gray62
          Hi James, the conical face of the clutch was covered with leather.
          Graeme
          #205195
          Roy James 2
            @royjames2
            Graeme W, Thank you, overall, quite thick stuff at over 1/8"..
            james
            #205197
              I'm sure some people have used cast iron on cast iron.
              Gray62
                @gray62
                Quite true Neil, in fact the cone clutch on my Studer cylindrical grinder is CI on CI and works very well
                #205202
                  Posted by Roy James 2 on 21/09/2015 18:29:23:
                  james
                  The author specifically mentions 'old leather belting'
                  I suspect that this was machine belting [rather than what holds your trousers up].
                  Roy James 2
                    @royjames2
                    Thanks to you all,
                    I have a couple more questions regarding said clutch, can I use copper as a bearing (5) on the counter shaft
                    pulley, it's only 6" dia, (unit all made many moons ago). I am considering casting the cones in ali, is there a reason
                    why parts 3&4 are separate, could they be made as one ? ( Bit daunting having to cut threads ).
                    james
                    #205372
                    daveb
                      @daveb17630
                      Copper isn't ideal but why bother? Porous bronze bushes are not too expensive.
                      #205539
                      Robbo
                        @robbo
                        James,
                        Parts 3 & 4 are separate as there was at the time a perceived difficulty in buying alloy of the required diameter in the necessary thickness. So the part was made in 2pieces. Nowadays material should be available to make it from a single piece.
                        #205578
                        Robbo
                          @robbo
                          James,
                          I have sent you a message about the clutch, check your inbox, top green bar on screen, second icon from left.
                          #205582
                          john fletcher 1
                            @johnfletcher1
                            I made the clutch for my ML7 and it worked well in the end. I did use bit of soft leather belting, initially the clutch slipped badly, then some one suggested I get a block of rosin as used by violinists. I crushed the rosin into chips then into a powder. I ran the lathe and opened up the clutch and sprinkled in the powder, did it a couple of times and the problem was solved. I still have the magazine and drawing somewhere. John
                            #205593
                              Leaded copper is actually used as a bearing material, comparable to babbitt metal, but its main limitation is that it wears easily. I would avoid it as constant lubrication would be critical..
                              Roy James 2
                                @royjames2
                                I am going to the Midlands Exhibition, I would like to buy a 4", 4 jaw adjustable chuck for the old Myford ML2, can anyone recommend one of the many sold by the like of Chronas etc? Would also need a back plate. Is it easy
                                to fit?
                                Have to cut the keyway in the shaft of the clutch mod, I have no miller, nor verticle slide, how to do it?
                                james
                                #207876
                                David Clark 13
                                  @davidclark13
                                  It is easy to fit. Just turn it on the lathe you are using the chuck on so it is true. Hold the shaft in the chuck supported by a centre, use the back gear to stop the shaft from rotating. Cut the slot with a lathe tool ground to fit used on its side and rack the carriage back and forth to form the groove.
