DRO
DRO
  • #761185
    grahammarch
      @grahammarch
      Hi all I recently purchased from a guy on a Myford Facebook forum a brand new never used EM 750 series DRO by ems international now currently owned by AMTS-NW
      does anyone have experience of owning one of these DRO, and would like to know what they are like
      I want to install it on my Myford super7 and want to embed the optical slide on the underside of my cross feed slide if this is possible by milling a channel out, any info would be greatly appreciated
      i recently installed a tachometer which seems to work great, now I’ve just got to learn how to use the lathe properly haha IMG_4806IMG_4805IMG_4804IMG_4801IMG_4802IMG_4803
      #761189
      Neil Lickfold
        @neillickfold44316
        There is not enough height to have a glass scale under the cross slide. The best you could do, is to make an extension for  the back of the cross slide and have it all extended out the back of the machine. Otherwise it will be installed on the tailstock side of the cross slide. I would avoid installing on the chuck side of the cross slide. I put in the magnetic type with the reader on the back of the saddle and the magnetic strip is also on an extension, like the MDRO one.
        #761192
        Harry Wilkes
          @harrywilkes58467
          Neil same here seems to work fine !
          #761197
          grahammarch
            @grahammarch
            Its not a glass scale it’s a magnetic one
            #761238
              Have a look here at the fully internal option, should give you an idea where the mag strips can be fitted although you may need to alter a bit as I suspect your read heads are a bit larger.
              #761258
              grahammarch
                @grahammarch
                Thankyou Jason that gives me a bit more information
                #761260
                  On JasonB Said:
                  Have a look here […]
                  I did … and I’m very impressed
                  https://microdro.com/the-story
                  [ maybe, one day … ]
                    The DRO and it’s maker Electronica Mechatronic Systems are new to me.  Not the usual Chinese fare – EMS are an Indian company.    A quick look at the Manual suggests the DRO is feature-rich, which made me wonder if it’s over the top for a lathe?
                    It’s a 3 axis DRO, when a lathe only needs 2.  Though it will work fine on a lathe with only 2-axes connected, this DRO delivers full value on a milling machine or grinder.  As Graham has said the lathe is new to him, I assume he’s not got a mill yet?  If a milling machine is on the cards, and I recommend one should be, then a better strategy is to fit this DRO to the mill.
                    In the meantime, I suggest putting a temporary hold on gadget fitting.  More important, I suggest, to learn how to drive the lathe in basic form than for a beginner to start by fitting go-faster accessories.
                    • No harm in fitting a tachometer to a Super7 as supplied by Myford, except it has 14 fixed speeds of: 27, 39, 54, 77, 95, 135, 210, 300, 420, 600, 740, 1050, 1480 and 2105 rpm determined by the belts and backgear. As it’s not difficult to know how fast the lathe is spinning, a tachometer doesn’t add much value, so fitting one may have been a time-waster!   Tachometers are valuable on lathes with continuously variable speed control; maybe Graham’s Super 7 has been upgraded with a 3-phase motor and VFD, in which case his tachometer is useful.
                    • Whilst fitting a DRO to a mill is a no-brainer, they’re less obviously value for money on a lathe.   For example, in my workshop the dials are good enough.  Depends on what the lathe is used for though!  A DRO advantage is their ability to switch between metric and imperial on the fly, but this conversion feature is low value to me because I work almost entirely in metric. My rare need to work in Imperial is satisfied with a calculator.  On the other hand, a workshop obliged to constantly mix Imperial and Metric would save a lot of time and avoid mistakes by fitting a DRO.
                    I advise a beginner with a Super 7 to buy a copy of Sparey’s “The Amateur’s Lathe”, and work through it carefully.  Build knowledge and understanding by reading the theory, step by step, then try to apply it.  A fair amount of skill is required, and it’s acquired by practice, not by fitting a DRO.   I recommend Sparey because he writes well and covers the theory relatively painlessly – almost no maths!   Sparey’s book is contemporary with Myford lathes, making his advice a good match to a Super 7.   The main problem with Sparey is he doesn’t cover stuff that hadn’t been invented in 1948!  So don’t expect advice on carbide inserts, speed controlled lathes, brushless motors, or anything digital!  For that look for something modern like Neil Wyatt’s Lathework for Beginners.
                    Another advantage of learning by using is that it highlights what’s really needed.  A few hours tedious sweaty hacksawing might persuade a beginner on a budget that he needs a band-saw far more than a DRO.  And a milling machine far more than a posh tenths micrometer, surface table and Gauge Block Set!
                    Beginners, including me, often start out with hazy ideas about what their workshop is for.   Tends to lead to a burst of unwise purchasing at first, buying tools that get very little use in the long-run.   Six months in the workshop clarifies what the owners interests are and what he needs to invest in.
                    There are always exceptions!   A friend is a keen motorcyclist and he owns an immaculate fully equipped workshop.  Nothing cheap in it –  Snap-on tools and cabinets, and everything else is pro-quality equipment.  Money is no object.   He freely admits he doesn’t use any of it – when his bikes need work, he has it done by the dealer.   He thoroughly enjoys pottering in his workshop, keeping it spotless, buying the best, and knowing that if he had to, he could maintain his bikes.  Not how I work – my workshop is purpose driven, with tools bought to do a job, considered consumable, and I don’t care one jot about brand-names.
                    If you know what you want, get on with it, otherwise it pays to invest time in discovering what’s really needed.
                      EMSi used to be at several of the Ali Pally shows and ran an advert in ME at some time. I seem to think they provided the DROs that were fitted to some of the “new” Myfords again hidden ones.
                      Their read heads went smaller than those sold by Machine DRO and would have been the supplier I would have used had I got round to fitting a DRO to my lathe as I wanted to hide the cross slide and have summing of the topslide & carriage which their consols did.
                      #761313
                      Fowlers Fury
                        @fowlersfury
                        A doubtful contribution to your original posting, but MEW carried a couple of articles I produced on fixing a “M-DRO” 3-axis DRO to my Myford S7 – beginning May 2018.
                        Clipboard_10-26-2024_01
                        SOD’s words of wisdom (above) are as usual generally endorsed but I wouldn’t be without the DRO on my S7. Accepting the ravages of senility – a 3 axis DRO suitably fitted provides two big advantages for me:-
                        (1) with the S7 becoming looser in its old age, relying on the index wheels is more difficult than reading the neon screen numbers especially having to make a 2nd approach when turning down some rod to ± a thou.
                        (2) As presbyopia takes its toll, reading the divisions on the Myford’s index wheels is not always easy.
                        The 2nd MEW article contained a table of measurement comparisons between Myford’s index wheels, a Mitutoyo digital caliper and the DRO read-outs. The DRO’s performance was consistent & impressive.
                        I think I retain copyright for the articles so if they’re of any remote interest whatsoever & you don’t have access to the MEWs, send me a PM.
