If you discount machines with round columns, tilting slides & swivelling heads you will not find a lot of choice !
I noticed a small ad in the latest issue of MEW for an Axminster 6 speed milling machine (in Derby, I think) – IIRC, these are Taiwanese clones of the Emco FB2 & Axminster marketed them as the "VHM", as the head can be swivelled to place the spindle horizontal for more machining options – the column also rotates in the base to give even more options. It has a 24" by 6" table, with 15" by 5 1/2" travels – 2MT spindle in a quill with 1 5/8" stroke and 6 geared speeds – around 14" maximum clearance between spindle & table – these are compact machines but with a reasonable capacity. Look up the FB2 on the lathes.co.uk site – the clones are all but identical.
While this is a round column mill, it has a full length key to maintain head alignment. It is also swivelling head (as above), but my similar machine is no great problem to align & it doesn't seem move out of position under reasonable machining loads. If I could find any shortcoming, it is the lack of fine feed to the quill. I have an Emco brochure for their original machine which gives the weight as 110kg – the column & head removes easily from the base as a unit, and I could move each part on my own (with a bit of puffing & grunting !).
Get in quick while it's still available !
Nigel B.
