Workshop warming
Workshop warming
Home Forums The Tea Room Workshop warming
Viewing 25 posts - 1 through 25 (of 61 total)
  • #596156
    michael howarth 1
      @michaelhowarth1
      Although well wrapped up, it felt flipping cold in the workshop this morning. So much so that I abandoned it at 1130. I could have switched on my electric heater…..3x1kw bars…..but we all know why I didn't…..or am I just being silly. It has set me thinking though, that if at the end of April I am forced to beat a retreat, what am I going to do in December, January, February and March? Without getting into the climate change debate there is not much evidence of global warming in this corner of England.
      The options are not very attractive. I could Just shut down for those months and possibly bring a bit of work indoors. I could use my current heat source, shut up and just pay the extortionate energy bills. I could even abandon the hobby altogether and sit and go to seed indoors. I am just on the right side of 80 at the moment so maybe this is a nudge in that direction. Perhaps working to a daily or weekly energy budget and abandoning ship when this is reached would be possible but it would be pretty inconvenient in the middle of some work. What about infra red heaters that apparently will warm me but not waste energy on warming the air around me?
      Whilst the 2022/23 winter is still some months ahead I am trying to think of solutions but not making much progress. Any thoughts, members of the jury?
      Mick
      #36842
      michael howarth 1
        @michaelhowarth1
        What to do about high energy bills
        #596168
        Bill Phinn
          @billphinn90025
          Dress technically, Mick.
          A goose-down or heated body warmer and hat. When really cold, thermal base layers as well.
          Just avoid long, or at least floppy, sleeves at all costs.
          Edited By Bill Phinn on 28/04/2022 12:51:31
          #596169
          colin hamilton
            @colinhamilton16803
            I've got a space heater which is good but of course you need to buy the fuel. I also put in a log burner which is great and I can scavenge most of the fuel but I find myself sitting in front of it drinking tea!!
            #596172
            Ex contributor
              @mgnbuk
              I bought a vehicle diesel night heater kit ( like this ) & fabricated an angle iron frame to hold it and a 12V PSU for heating my garage/workshop.
              Making the frame was a bit of a pain & if I were to do the job again I would start with an "integrated" version like this Diesel heater and power it using a 12v PSU (the heaters take around 10A to start up & around 2A when running at temperature). The integrated versions have a built-in 5 litre tank, but mine sips from a 25 litre oil drum.
              Be aware that the exhaust must be routed outside the building & that the exhaust pipe gets very hot !
              They will run on either red or white diesel, parafin or heating oil & a 5Kw version uses about half a litre an hour running flat out. Mine is a bit noisier than an electric fan heater inside the garage (but not objectionably so) & the exhaust (with supplied silencer fitted) is a low purr outside the building . Unlike an electric fan heater it does actually warm the space !
              Nigel B.
              #596174
              Jon Lawes
                @jonlawes51698
                I have the same system as Nigel (but integrated), I drilled a hole in the brick wall for the exhaust and have two outlet ducts in the workshop. I also have two carbon monoxide detectors of different brands because I'm rather paranoid about fumes having had a friend brain injured by Carbon Monoxide.
                It's very effective, some people have had varying reliabilty but I think making sure you run it for a decent amount of time so it doesn't soot up helps.
                #596177
                jaCK Hobson
                  @jackhobson50760
                  I got a heated vest/gilet which works very well. Mine has a heated collar which is nice.
                  Edited By jaCK Hobson on 28/04/2022 13:31:37
                  #596181
                  Roger Clark
                    @rogerclark
                    Mine's the same as Nigels, been running it in a 5mtr x 7mtr workshop with 4" insulation in the roof and 2" in the walls.
                    I've had it for 3 years now, I start it about a hour before I go into the shop to take the chill off, so far I've bought 150 litres of kerosene @ less than 50p per ltr and reckon I've got enough to last through the next winter plus. The bonus with these heaters is that it circulates the air in the shop so doesn't introduce cold damp air from outside.
                    Never had an issue with it.
                    Roger
                    Edited By Rockingdodge on 28/04/2022 13:50:47
                    #596182
                    DMB
                      @dmb
                      So the old chestnut is back, albeit in slightly different form.
                      1 To keep workshop even slightly warm-ish, you need to use something that's on 24/7, in my opinion (and experience.) Having said that, there is also a timer in circuit, allowing a switch off for a few hours in the warmest part of the day. This being adjusted according to season.
                      Even a garage can be insulated, the initial cost being recovered in the saving of actual heat.
                      If heater(s) connected via a thermostat to limit rise in temperature, that should help to make running cost a bit more economical.
                      Every large machine, e.g., lathe, mill, etc., are covered when not in use, covers will trap heat rising from the heater in the drip tray. Any escaping heat will gently warm the rest of the workshop.
                      My system works well for me in the "Sunny Sarf" (Sussex) and it hasn't bankrupted me yet.
                      #596184
                      Adrian R2
                        @adrianr2
                        Is your workshop insulated and draught proofed? If not, can you make it so or at least improve it before autumn?
                        #596185
                        Ady1
                          @ady1
                          I got a fleecy "snood" as an xmas present and went out to buy 2 more within a week because they are so good
                          Wish I'd known about them when I used to hillwalk, been wearing one practically every day since I got it
                          We don't get much global warming in Jockland
                          Edited By Ady1 on 28/04/2022 14:06:36
                          #596188
                          Neil Lickfold
                            @neillickfold44316
                            Mine, I have a heat pump AC unit and keep it about 20c all year round. Put the most insulation in all the walls possible and the most insulation in the roof. The 1 window is double glazed with a heat rating of 63 what evers. Out here in NZ the std double glazing is only around 15 to 20 for the insulation value. I found that having it set on a permanent low fan speed, in the summer months I have it on cooling, and now we are approaching winter, I have switched it over to heating. Running costs year round is about $350 for the year approximately. The floor of the workshop is concrete but on this polystyrene block system. The houses next door were done with a plastic dome to insulate the concrete. I have a wood cabin for making model planes in and is where I also do my gluing up work. Last year I put a heat pump in that one as well, and have done the same, run the fan only on low and in the winter have it on heat only mode and summer is cool only mode. It is only a 10 m2 room and cost about $3 per week in electricity on average year round. It is also well insulated, and has a very nice double glazed door that came from the old house.
                            When ever I had the heat pumps on only when I was in there, it was not all that much cheaper to run. So I just leave them running year round. At the 55%-60% humidity, 20c is not too cold. I also find that things don't rust either as it is kept well above the dew point.
                            I went with LED lighting in the outside cabin and I like it very much. I am not sure if the LED batten lights use any less power than the fluro tube lights.
                              INSULATE!
                              No point in spending money to keep everyone and everything else warm!
                              Admittedly the shop is small, but a thermostatically controlled 2 Kw fan heater brings it up to temperature, aided and abetted by waste heat from the machines, then operates on a very low duty cycle.
                              #596204
                                My approx 35 cubic metre workshop is comprehensively insulated and pretty well draght-proof. Over 100mm of insulation and no windows. Cool in summer and cool in winter – it is kept dry and above dew point by running a 375W desiccant dehumidifier for a couple hours at night, or longer if the weather is very cold.
                                I’ve solved the winter ‘coolness’ with a diesel air heater similar to the one mgnbuk showed under his ‘like’.
                                Mine delivers a little over 4kW, I think. I can turn it on remotely and ten minutes on the mid-range setting is enough to make the worksop air temperature acceptable. I usually soon turn it down to minimum – but I expect I will need to run it at ‘full whack’ occasionally, to avoid any coking up in the combustion chamber.
                                If you were to go this route, my advice is to check the specifications carefully. That one shown indicates 0.64l/h fuel usage. They are notoriously inaccurate with their claims – mine will not provide a sufficient pumping rate to provide the claimed heat output. Otherwise, it has been reliable (so far), was easy to install and doesn’t cost anywhere near as much as using leccy for the heat supply!
                                #596208
                                jimmy b
                                  @jimmyb
                                  I run a 3kw radiator for 6 months of the year.
                                  I'll spend the money while I have it.
                                  Jim
                                  #596209
                                  Baz
                                    @baz89810
                                    Totally agree Jim I am the same, dehumidifier runs all year round and as much heat as is needed during winter, I would rather spend the money on enabling me to enjoy my hobby, if I keep it no doubt the care home will get their grubby fingers on it and having first hand knowledge of how the mother in law was treated in a home they will get as little as possible from me.
                                    #596221
                                    Mike Poole
                                      @mikepoole82104
                                      Posted by Ady1 on 28/04/2022 13:58:49:
                                      When I was a hairy 1970s apprentice we had to wear a snood to avoid being scalped alive by rotating machinery, ‘snood’ seems to cover a variety of garments, the version we had to wear was a hat with net bag to take care of our treasured locks, it seems now to be commonly used to describe a neck and head warmer.
                                      #596227
                                      Roger Williams 2
                                        @rogerwilliams2
                                        Planar 5kw diesel heater like a few have mentioned , absolutely marvellous.
                                        #596241
                                        Martin Cargill
                                          @martincargill50290
                                          In our workshop the Gaffer allows us to all huddle around a candle. If the workshop temperature drops below -10 he will even allow us to light it.
                                          #596260
                                          Calum
                                            @calumgalleitch87969
                                            A couple of months ago I realised that condensation would do for everything in my workshop if I didn't address it. I now have a very cheap fan heater attached to a little plug-in thermostat. It kicks in when the temperature drops to 6C and off again at 7C. It obviously consumes some power but watching the meter for the last couple of months I can't discern any impact, and we don't use electric for heat or hot water at all here.
                                            Obviously 7C is not a lot but it made the workshop tolerable for me. I did have an old gas fire in there which gets the place toasty in short order, but it gives off so much water it's like a sauna after an hour or two. Since putting the fan heater in it hasn't been on once.
                                            #596284
                                            Leendert Brouwer
                                              @leendertbrouwer51034
                                              Mount an infra red panel above the place where you are the most in your workshop. After you insulate your workshop.
                                              #596314
                                                Calum,
                                                It rather depends on your location as to what climatic conditions you might have to contend with. Also the type and location of your work area will be quite important.
                                                It cost about a hundred quid more than a cheapish fan heater (OK, fan heaters are often available as surplus to requirements). My installation included a CO monitor for safety. My location is in my ‘settings’, so easily available to all. My fuel, for the foreseeable future, will actually cost me nothing, as it is ‘in stock’. It needs using up before I pop my clogs.🙂
                                                The convenience of use (once installed), cost of fuel and ‘warmth with dry air’ were my considerations before purchase. I can see that leccy may well soon be 50p/unit (hopefully not), so my investment will likely soon pay for itself – it makes working out in the workshop a comfortable all year hobby.
                                                On top of that lot, with minimal electrical requirement for the air heater, I a) won’t be overloading my workshop supply and b) I have the opportunity to run my workshop from a battery/inverter supply if needed.
                                                Edited By not done it yet on 29/04/2022 09:58:07
                                                #596321
                                                Peter G. Shaw
                                                  @peterg-shaw75338
                                                  Like you, Mick, I'm just on the right side of 80, and yes, I do shut down for the winter months which is when I delve into genealogy.
                                                  In respect of heating, my workshop is a garage, and has been left as such firstly because when I'm gone, it will still be a garage, and secondly, I don't think the expense of insulating it is justified at our age. I have therefore, an ancient 1kW convector heater, and a 3kW, with two settings, fan heater, so if necessary I can call upon 4kW of heat. Ok, it's expensive, but so what, I can't take it with me, and in reality, it's only a small amount compared to the really big power users in the house – six storage heaters if we use them all! Plus, of course, the electric hob and the electric double oven.
                                                  I should also point out that both the lathe and the milling machine are fitted with some small cabinet heaters to keep them slightly above air temperature thus avoiding condensation and the resultant rusting.
                                                  As I'm writing this, I have actually been in earlier this morning and switched on the 1kW convector heater in an attempt to remove some of the cold.
                                                  Well, those are my thoughts.
                                                  Cheers,
                                                  Peter G. Shaw
                                                  #596322
                                                  Bob Worsley
                                                    @bobworsley31976
                                                    I find the best heaters are the halogen type, warm you up. Alternative is to use the halogen work lights to illuminate.
                                                    But insulation is the answer, do some calculations on wall and ceiling area, U values etc and get an idea of what the heat loss is at a 20 degree inside/outside difference. The Kingspan/Celotex foam insulation is the best stuff obtainable, 0.02 W m^2 m C.
                                                    As has been said, no pockets in shrouds, spend it until gone then go for a handout from the council, just like everyone else.
                                                    #596324
                                                    Mike Hurley
                                                      @mikehurley60381
                                                      All the ideas about heated coats and thermals etc are fine, but at the end of the day, if your hands are cold, the tools and machinery are cold then its very difficult to work properly, and even slightly dangerous. Insulate the workshop as much as you can, and I'm afraid to say it but just heat it as you feel best. I realised many years ago that you can't take it with you, and these days nobody appreciates people being frugal. I fully echo what Baz said a few postings earlier.
                                                      Obviously we don't know your personal circumstances, but if this hobby is good for you, think upon it, and try to continue to get the most out of it. Several good space-heating suggestions in this thread, some which I will be investigating further on my own behalf!
                                                      All the best.Mike
