What does diamond turned mean?
Home Forums The Tea Room What does diamond turned mean?
  • #35770
    Ian Parkin
      @ianparkin39383
      #454968
      Ian Parkin
        @ianparkin39383
        I keep on seeing this term applied to mainly aluminium parts saying they have been "diamond turned"
        what does this mean?
        Mpp cameras have DT parts last made in 1988 so its not a new thing
        #454970
        martin perman 1
          @martinperman1
          See here **LINK**
          Martin P
          #454971
            Turned using a diamond-tipped [as distinct from diamond-shaped] tool
            Edit: Martin found a good link whilst I was typing.
            Edit: Probably worth noting that the idea is much older than MPP … Horological jewel makers used shards of Diamond for hand-turning Sapphire and Ruby.
            Edited By Michael Gilligan on 02/03/2020 08:40:14
            Edited By Michael Gilligan on 02/03/2020 08:54:54
            #454972
            Clive Brown 1
              @clivebrown1
              Link
              Wiki has a good explanation
              Edited By Clive Brown 1 on 02/03/2020 08:41:03
              #454973
              Ian Parkin
                @ianparkin39383
                So going back to a simple MPP camera knob why would you use a diamond tipped tool rather than a normal tool?
                in the 60's to 80's
                #454974
                  Posted by Ian Parkin on 02/03/2020 08:48:34:
                  in the 60's to 80's
                  To give that lovely multi-coloured reflection … perceived quality !
                  … Compare iridescent beetles, Compact Discs, etc.
                  Edited By Michael Gilligan on 02/03/2020 09:01:22
                  #454977
                  Bill Pudney
                    @billpudney37759
                    When I had to work for a living they had a diamond turning machine. It was in it's own air conditioned room and sat on it's own huge concrete pad. It was used to make optical mirrors from 6061 T6 al.alloy. Workpieces would come off the machine finished with an absolutely amazing finish, which despite being from al. alloy didn't corrode. Don't ask me why! The DT process took tiny (shallow DOC) cuts at startling rpm. Very expensive machine.
                    Got to go The Boss is breathing down my neck wanting the PC
                    cheers
                    Bill
                    #454979
                    Russell Eberhardt
                      @russelleberhardt48058
                      Diamond turning used to be used for re-finishing commutators in DC motors and generators to prevent the copper smearing across the insulator segments.
                      Russell
                      #455000
                      Clive Foster
                        @clivefoster55965
                        The Wikipedia article is interesting but does rather overstate the technology needed to produce optical finish standards.
                        The high speed plain bearing Holbrook C lathes, originally developed for the atomic weapons folk to handle materials that couldn't effectively be ground, were also supplied for diamond turning duties. We had a sample originally made on one such machine in the "aren't we wonderful" section display cabinet back at RARDE which was well up to decent optical standards. Whatever ones views on the overkill nature of supplying a full on tool room lathe with all the trimmings for basic plain turning duties a steel spindle spinning in white metal bearings is hardly high tech.
                        These days diamond turning tools, especially for alloy wheel refurbishment and similar duties are Poly Crystalline Diamond (PCD) inserts. Same sizes and styles as the usual carbide, CBD etc but diamond in the matrix. Nice thing about modern inserts is they can take reasonable cuts and are often able to handle roughing duties as well as finishing. The alloy wheel folk need diamond tools due to the alloys being incredibly abrasive.
                        #455008
                        John Haine
                          @johnhaine32865
                          It is possible that actually they are referring to an "engine turned" pattern on the knob in the shape of diamonds – what we could also call knurling. Such patterns can be produced on a "straight line" machine. A/k/a guilloche. Ian asks in the 4th post "why would you apply this to a simple camera knob" – well, to make it easier to grip!
                          #455011
                          Tony Pratt 1
                            @tonypratt1
                            My experience of diamond turning was the finishing of commutators on A C Delco windscreen wiper motors.
                            Tony
                            #455012
                            Norman Billingham
                              @normanbillingham91454
                              I used to do bits of consultancy work with a company which makes intraocular lenses for cataract operations. They were turned to shape from acrylic plastic using a CNC lathe with diamond tipped cutting tools
                              #455017
                              Ian Parkin
                                @ianparkin39383
                                John H
                                the knobs in question were supplied as lengths pre knurled and then diamond turned
                                I was just surprised to learn such an expensive process on a lowly camera part
                                #455018
                                Ian Parkin
                                  @ianparkin39383
                                  But as Micheal G said you can see an iridescence in the top….would you not see that with any other type of cutter?
                                  #455021
                                    Same category as "machined from billet" and gold plated mains plugs.
                                    #455028
                                      Decorative "diamond turning" leaves the surface like a record and the grooves catch the light and give a holagram rainbow coloured effect as you move the item in the light. Common on some alloy car wheels etc. Not always cut with a diamond.
                                      Edited By JasonB on 02/03/2020 13:17:09
                                      #455035
                                        If you were a company called Micro Precision Products
                                        Surely you would … just to prove you could.
                                          I don't think that i would describe a MPP as a "simple camera" The "plate" and Field cameras were definitely not! They were beyond my wallet, and lived up their maker's name!
                                          #455230
                                          Ian Parkin
                                            @ianparkin39383
                                            I was always under the impression that MPP’s were rather cheaper than the competition and looked down upon by the cognoscenti
                                            having said that i suppose even £75 was a lot in the 50’s and 60’s
                                            having said that I’m quite happy with my models that i own
                                            certainly Basil Skinners book talks about the lack of funds at the factory for development
                                            #455272
                                            John Reese
                                              @johnreese12848
                                              hu1Q
                                              This is Dan Gelbart's precision lathe for diamond turning.
                                              #455296
                                              Mike Poole
                                                @mikepoole82104
                                                Lots of alloy wheel refinishers boast a diamond turning machine for the effect where the wheel is painted then turned to give the bright edges to the spokes followed by complete clear lacquering of the wheel. I assume it is just a diamond tipped tool to provide a very high as machined finish to avoid having to polish the spoke edges after machining.
