Stuart Victoria Query
Home › Forums › Stationary engines › Stuart Victoria Query
  • #540396
    Clive Brown 1
      @clivebrown1
      I'm just starting to build a Stuart Victoria engine.On examining the drawngs, I'm slightly surprised that the crankshaft is positioned 1/4" above the cylinder centre-line. Does this height difference have a noticeable effect on the running of the engine, eg a slightly uneven exhaust beat. Do any other Stuart horizontals have this feature? Just curious.
      #3450
      Clive Brown 1
        @clivebrown1
        #540402
          Should not be. The ctr height of the hole in the main bearings is 5/8" from bottom. (wrong on the 1993 drawings) The ctr line of the holes in the cylinder support brackets are 5/8" from bottom and adding up the various bits of the cross head guide put the cross head pin 5/8 up.
          Horizontal green ctr line runs straight through all three points
          You may want to have a look at this thread where depending on what drawings and or book you are working from there are errors, I'll going to post a set of corrected drawings soon if you can wait.
          Edited By JasonB on 18/04/2021 17:16:14
          Edited By JasonB on 18/04/2021 17:21:42
          #540417
          Clive Brown 1
            @clivebrown1
            Thanks Jason. I have the 1993 drawings. I had read the linked thread where discrepancies were pointed out but these seemed to relate to the longitudinal positions of the cylinder, slide-bars etc. I've fabricated the bed and was intending to measure up as the job progressed and make items such as the con-rod to suit. However, my drawing clearly dimensions the main bearings at 7/8" above the bed compared with the cylinder at 5/8". Scaling off the drawings also confirms these figures, the draughtsperson must have been having a bad day. I'll make my bearings 5/8" as you advise.
            I await your corrected drawings with interest.
            PS.I wonder how many Victorias have been made with the height difference?
            Edited By Clive Brown 1 on 18/04/2021 18:44:54
            #540462
            Steve Withnell
              @stevewithnell34426
              Mine certainly has! It's not getting rebuilt now…
              Victoria
              You can hear the big end knocking, that I will fix one day Usual shortage of 'roundtuits'.
              Steve
              #540572
              duncan webster 1
                @duncanwebster1
                Lots of GWR locos had the cylinder centre line above the axle centre line, didn't seem to bother them over much. Makes valve timing a bit different, but Steve's video shows it doesn't matter much
                #540573
                  I think the problem was a bit of early cut & paste when the '93 drawings were done and a few bits from the beam got copied rather than having the subtle alterations done for the Vic.
                  I've a set of castings for a smaller ball hopper engine that like the full size has an offset crankshaft.
                Home › Forums › Stationary engines › Topics
