Glass Cutter Point?
Glass Cutter Point?
Home › Forums › Help and Assistance! (Offered or Wanted) › Glass Cutter Point?
  • #615435
    Martin King 2
      @martinking2
      Hi All,
      I have a very nice antique diamond Point glass cutter that sadly is missing its diamond.
      Does anyone know how this might be replaced as I have several other scrap ones that could donate a diamond?
      Looks a bit like solder?
      #34086
      Martin King 2
        @martinking2
        #615437
        Clive Brown 1
          @clivebrown1
          I think that you can use a low melting point alloy called "Cerro Matrix" which expands when it solidifies. That's what my FiL, who was a grinding expert, used for wheel dressers.
          #615440
          Martin King 2
            @martinking2
            So perhaps gently melting the tip where the diamond was, the dropping in the replacement might work?
            Also probably the way to remove the point that will be used from the old cutter?
            Cheers, Martin
            #615441
              Very likely, Martin
              Noting also that “Cerro Matrix” is probably in the same family as CerroBend … but may well be a slightly different [tougher?] formulation of alloy.
              Speedy Builder5
                @speedybuilder5
                You could use one of these ?
                #615477
                David George 1
                  @davidgeorge1
                  I made one from a piece of silver steel which I drilled the end deeper than the diamond but a loose fit. I dropped the diamond in with some flux and with it held down with a titanium pin I silver soldered over the diamond with a low temperature silver solder. After it had cooled I ground back the end with a champher till the tip was sticking out. The body of the diamond which was still held by the solder was holding the diamond in situ. Hope this helps.
                  David
                  #615485
                    A little bit of history here: **LINK**
                    https://www.aviationancestry.co.uk/?home/&searchQuery=MiningAndChemical&startYear=1909&endYear=1990&&searchOrder=ASC&pageNum=2
                    Edit: __ is anyone sufficiently interested to go searching for the document referenced here:
                    Edited By Michael Gilligan on 29/09/2022 18:54:53
