Clear Finish for Steel
Home Forums Hints And Tips for model engineers Clear Finish for Steel
  • #216102
    John Lucas 5
      @johnlucas5
      What is recommended for a clear finish on a steel model?
      Something to stop corrosion from modest handling but not look like a heavy lacquer. I'm finishing with 800 or 1000 grit to leave a satin surface with some details polished.
      #30548
      John Lucas 5
        @johnlucas5
        #216108
        Clive Hartland
          @clivehartland94829
          There is a clear lacquer that is used to seal PC boards, its a spray can and I am sure its acrylic. I have found this to be good for surface covering. Alternatively you can use Cellulose clear lacquer, 'Airplane dope'.
          I have had good results with both on steel and brass.
          #216112
          steve de24
            @stevede2433577
            John, clockmakers use Horolacq. I think it's available in clear. Steve
            #216115
            Andrew Entwistle
              @andrewentwistle
              I use Rustins metal lacquer for keeping a bare metal appearance but protecting from rust. It goes on like water without leaving brush strokes but has kept anything lacquered in the cellar rust free for more than three years now.
              Andrew.
              #216155
              Ian S C
                @iansc
                It's not that hard wearing, but hair spray works.
                Ian S C
                #216348
                Bob Unitt 1
                  @bobunitt1
                  Posted by Andrew Entwistle on 12/12/2015 23:30:30:
                  Andrew.
                  I'll second this – I made a gunmetal and steel medieval mortar about 6 years ago, both metals showing signs of corrosion after a few weeks on the mantlepiece. I cleaned it up again and coated it with Rustin's Metal Lacquer, since when it's sat on that same mantlepiece, sometimes being picked up for examination by sweaty hands, and it still looks like it did the day it was lacquered.
