Engineer’s Blue
Engineer’s Blue
Home Forums Hints And Tips for model engineers Engineer’s Blue
Viewing 25 posts - 1 through 25 (of 56 total)
  • #67798
    Clive Barker
      @clivebarker72854
      I have been reading notes on another thread about ‘engineer’s blue’ and ‘layout blue’. I am not able to source either where I live (and overeas post is not reliable).
      In that thread alternatives were suggested to proprietory brands of ‘layout blue’ which I will try, but does anyone have a good alternative for ‘engineer’s blue’. Out of desperation I have been using thin enamel paint, but it isn’t really satisfactory.
      Any advice would be welcome.
      Thanks,
      Clive.
      #30331
      Clive Barker
        @clivebarker72854
        An alternative?
        #67799
        Peter G. Shaw
          @peterg-shaw75338
          I think it was Tubal Cain who once suggested whitewash or presumably a thin white emulsion paint for castings.
          Other ideas are some sort of copper (sulphate?) solution which leaves a thin covering of copper on the metal.
          Peter G. Shaw
          #67800
          Clive Barker
            @clivebarker72854
            Thanks Peter for your quick response.
            I think I misled you by referring to both layout blue and engineer’s blue in my intorduction. What I am really referring to here is the latter ie ‘Engineer’s Blue’- to help me in the final stages of fitting of two components to show clearly the high spots.
            Thank,
            #67804
            Ramon Wilson
              @ramonwilson3
              Hi Clive
              I don’t know of an alternative as such but when I discussed hand scraping with my friend John some time back for another post on here he showed me a tip for the very final ‘touching up’. For this he used a wet layer of ordinary methylated spirit which he allowed to flash off on the surface. This left a barely perceptible coating which showed the high spots extremely well.
              It’s just a thought but perhaps you could increase the colour in some meth slightly – contents from a felt pen maybe? and try that.
              Or another, though I hasten to add untried possibility, would be to get some ‘blue’ artists pigment and mix to a thick paste with some oil – indeed what about trying artists oil paint.
              Whatever hopes that helps some and if it works let us know how well.
              Regards – Ramon
              Edited By Ramon Wilson on 01/05/2011 14:12:44
              #67805
              Gordon W
                @gordonw
                In the absence of eng. blue, for testing fits, any semi-solid coloured greasy stuff should work. Would recommend lipstick, can you get it where you are without raising eyebrows? Just draw 3 or 4 lines .
                #67808
                John Stevenson 1
                  @johnstevenson1
                  Break an old printer cartridge open, after all engineers blue is actually a printing ink.
                  Used to be made by an old customer of mine Coates Lorilleux, before Sun Chemicals bought them out and they buggered off abroad.
                  John S
                  #67812
                  Ian S C
                    @iansc
                    Engineers blue, lip stick, it does’nt have to be blue.
                    Lay out blue, felt tip pen. Copper sulphate solution will give a light coppery film on the metal, not much use on brass of course. Stick to a broad tip felt pen. Ian S C
                    #67813
                    Donald Wittmann
                      @donaldwittmann92536
                      Like IanSC says, you can use a felt marker pen just make sure it’s a permanent type.
                      The best type for marking out metals is EDDINGS, although a Sharpie Magnum is a good alternative. Blue or Black does me on bright steels and Copper beryllium, I think Red would be good on Brass.
                      Donald.
                      #67815
                      Clive Barker
                        @clivebarker72854
                        Thanks to all of you, tho’ my original question was related not to marking out, but testing fits hence the differentiation between Layout Blue and Engineer’s Blue. As Ramon suggested in the past I have tried artist oil paints (Ultramarine I seem to remember) but it didn’t show as well as the real stuff. I found that to get the layer thin enough to test for a close fit, the contrast on steel or cast iron was certainly lacking. I didn’t try another colour supecting that it was the lack of density of colour that was the issue.
                        I thought your idea of lipstick was brilliant, Gordon. Yes, it is easily available bere, but I would be seen a mile from the shop – best to use my wife’s, when she is not looking!
                        Thanks to others for your suggestions for marking out.
                        Clive.
                        #67819
                        Ramon Wilson
                          @ramonwilson3
                          Hi Clive,
                          regarding the oil paint – in case you aren’t aware this can be thickened considerably to a grease like state by laying a good splodge of it on a piece of thick card. Left for a few hours the card will absorb the oil especially if it’s the grey rough finished type card and leave the paint very stodgy indeed. That may improve matters.
                          Lipstick is a new one on me too but with plenty of the real thing (blue) at hand I’ll give it a miss for now
                          Regards – Ramon
                          #67820
                          Colin Jacobs 1
                            @colinjacobs1
                            I use Tipex.
                            #67824
                            Pat
                              @pat
                              The problem with artists oil color is the viscosity is too high for use as fitters / micrometer blue.  Thin with turps or  paraffin to get the desired mix.  I keep a tube of prussian blue to hand as it does not migrate everywhere unlike the stuff sold in tool shops.   As far as I can remember prussian blue is favored as it is less chemically reactive than some of the other artists pigments.
                              As for marking out there are any number of alternatives to the traditional marking out blue and each has their own advantages and problems. Spirit based felt pen is good and enables notes to be made on the part as well! If the part is iron or steel then copper sulfate is good – gives a very thin copper coating through which the marking out scratches show clearly. Add artists prussian blue oil color to knot stopping ( a shellack and methylated spirit preparation sold the world over to stop wood knots bleeding through paint work. This mix is similar to marking out blue and it smells nice! Artists oil colors make good micrometer fitting blue and other colors are available and it comes in nice small tubes as well. Soot from a candle also works well.
                              Hope this helps – Regards – Pat
                              Edited By Pat on 01/05/2011 20:24:01
                              #67827
                              Mark P.
                                @markp
                                Hi all, for layout dye I’ve been using felt tip pens,dismantled and the contents put into meths.Felt tips from my local Wilco stores at 90p for 4,much cheaper than commercial dye and many pretty colours.
                                Regards Pailo.
                                #67828
                                Chris Trice
                                  @christrice43267
                                  I use a permanent marker pen. Perfect for testing the fit of tapers.
                                  #67830
                                  Nobby
                                    @nobby
                                    Hi All
                                    I use black felt tip pen as well thinned with meths same as Pailo for laying out
                                    Engineers Blue ? I prefer high spot blue ideal for shutting out tools and checking fits etc.
                                    my Son was an RAF fitter & uses a permanent marker Same as Chris
                                    Regards Nobby
                                    #67867
                                    Clive Barker
                                      @clivebarker72854
                                      Thanks all for your helpful suggestions. Was going to try to send you personal messages via the messaging option but it seemed too complicated.
                                      #91491
                                      peter amor
                                        @peteramor79798
                                        Stuarts Engineering Micrometer Marking Blue Ebay £3-05 46 years as a fitter and always used it for fitting taper keys ect Have fun Pete
                                        #91493
                                        Clive Hartland
                                          @clivehartland94829
                                          Clive to Clive, If its any help then gunsmiths use lamp black, a sooty flame held near the surface to be checked and it is easy to see where interferance starts.
                                          #91495
                                            @mike89748
                                            Dammit, Clive, you beat me to it! The sooty candle flame from an over-long wick works pretty much the same.
                                            Edited By Mike on 24/05/2012 15:46:34
                                            #91496
                                            Ian Fowkes
                                              @ianfowkes89537
                                              Someone briefly mentioned printing ink which strikes me as being an ideal engineers blue substitute, the thick gooey stuff as used in litho and other traditional print processes is oil based, will adhere to dry metal and will transfer easily on contact to another surface (that's what it does in it's intended use!) and should easily be available in Pakistan – perhaps you can scrounge the tiny amount you need from a friendly local printer – even an "empty" tin will probably yield enough. And it's available in any colour, even blue.
                                              Ian,
                                              #91501
                                                The problem with some of the suggestions for paint like substances is that if you don't clen them off the surface pate before drying then they can be a bit of a nuisance to get off and non setting is the target. Layout blue needs the opposite property which is why fast evaporating alcohol is the normal solvent..
                                                The requirement is some pigment in which every single particle is fractions of a thou thick. Cheapo paints might have some coarse bits in.
                                                Before commercial blue came along I believe red lead and chrome yellow (yeah yeah shock horror poisons alert) were used for the colouring but not sure of the carrier – glycerine for water based or vaseline for oil based perhaps.
                                                #91502
                                                Lambton
                                                  @lambton
                                                  Stuarts Micrometer Blue can be purchased from Arc Eurotrade £4.75 for a 32g tube that will last you a lifetime.
                                                  #91503
                                                  Les Jones 1
                                                    @lesjones1
                                                    Hi Clive,
                                                    You could try some of the ink from a ball point pen. I seems to have a similar consistancy to engineers blue.
                                                    Les.
                                                    #91507
                                                    robert ramage
                                                      @robertramage25020
                                                      Hi clive were about do you live?
