Collet chuck
Collet chuck
Home Forums General Questions Collet chuck
  • #513277
    Andy Sproule
      @andysproule22368
      Hi has anyone bought one of these and could tell this diameter marked on pic.Tried seller but no luck.
      Edited By JasonB on 13/12/2020 17:20:15
      #27822
      Andy Sproule
        @andysproule22368
        #513279
        JohnF
          @johnf59703
          Anybodies guess ! but less than 4.0" ?? however for the sake of £12 why not buy one from Arc ? You will then know the product and have recourse if there is a problem
          Chris Evans 6
            @chrisevans6
            I made a backplate for somebody a few years ago. Memory tells me 75mm. I have been known to be wrong though.
            #513282
            Chris Evans 6
              @chrisevans6
              #513283
              Robert Atkinson 2
                @robertatkinson2
                It would be useful of you at least specified the collet size. Even with this the size could vary from make to make.
                #513287
                  ER32 on a 100mm fitting.
                  #513289
                  Andrew Entwistle
                    @andrewentwistle
                    Based on pixel measurements from 100mm OD can't be far off 73mm.
                    #513290
                      Posted by Andrew Entwistle on 13/12/2020 18:00:33:
                      Could be 2 & 7/8 inches then surprise
                        I would think a basic caliper would be the tool to pick up and use? Even s good tape measure might be close enough? Whatever it is, it may well need a backplate making to fit it quite closely. That would/should be done by careful test fitting until the spigot is just the right size.
                        #513305
                        old mart
                          @oldmart
                          I have an er25 version on a backplate, of course, the register is loose for fine adjustment, after all, if the register is tight, you have to put up with whatever runout each collet gives.
                          You can buy them with a choice of 80, or 100mm outside diameters.
                          Edited By old mart on 13/12/2020 19:08:12
                          #513449
                            I have both ER25 and ER32 models.
                            I had to make backplates to fit to my lathe. They have the advantage of allowing long material to feed through, unlike the Morse taper type ,chucks (which are more suited to holding cutters in a Mill, in my view ).
                            #514060
                            Andy Sproule
                              @andysproule22368
                              Hi folks thank you for replies.I should have said it was er32 and the od was 100mm.
                              Edited By Andy Sproule on 17/12/2020 19:41:27
                              #514063
                              HOWARDT
                                @howardt
                                Mine is from Arc, ER25 as per their chart, 72mm register, 84mm PCD.
