Hi All,
I was doodling earlier today, planning a fabricated standard for a simple oscillator.
Could I invite comments on the rough sketches below.
I would like use JB weld for all the joints preferably without any other mechanical fixings.
The standard will be around 80-90mm high.
My plan would be to do all machining after it is fully assembled and cured, i.e machining the face and drill/reaming the crankshaft and trunnion holes.
I would add fillets to all the joints with the idea of giving the final appearance of a casting.
I have limited experience of using JB weld, my gut feeling is this would be a strong structure, but I do invite comments, thank you.
geoff
