KMyford Hard Rubber Bushes
Home Forums General Questions KMyford Hard Rubber Bushes
  • #473226
    Tas seamus
      @tasseamus
      Well here goes, first post. Following forum I see that there is a problem locating spare hard rubber bushes foe the counter shaft, part no.1227. would some kind member be able to provide dimensions as I have material which would be suitable.
      #27378
      Tas seamus
        @tasseamus
        Counter shaft bushes ML7
        #473373
        DiogenesII
          @diogenesii
          ..no-one's that keen to rush out and measure those filthy things, then..
          The overall width is 5/16", the flange is 3/32" thick. The major diameter across the flange is 1 1/2", stepping down to 1 1/4" for the reduced portion that the slots in the cover ride on.
          The bore is approx 1.10" (can it really be 1 & 7/64ths? -seems a ridiculous dimension to choose..), in any case, just make them to be a good push fit onto their spigots, and the reduced part to have a little clearance in the slots so that the bushes stay fixed on the countershaft head and the cover is able to slide up & over them easily..
          Welcome to the forum!
          #475550
          Tas seamus
            @tasseamus
            My thanks to Diogenese ll , I will progress with the bushes but probably with something like Deildren or similar, depending on what is available locally. Again my thanks.
            Seamus
