So I recently painted an xy table of mine and im having some strange problems.
The table is cast iron and was powder coated before I stripped it back to bare metal. I then filled the imperfections with body filler (which stuck like sh*t to a blanket btw) smoothed it off, cleaned it thoroughly with panal wipe and painted it with hammerite.
I know some of you will groan about hammerite but it's what I could get hold of in these uncertain times. And the finish doesn't need to be brilliant.
I gave it 2 coats and waited a day between each. I then waited another week for the paint to harden up before removing the masking tape. This is when the problems started. The paint seems to be flakey and chips at the smallest bump? Ive used Hammerite for years and it doesn't usually act like this? This was a brand new fresh can btw.
I couldn't be bothered to re do it so I thought I will just have to put up with it.
Next job. I bought some self adhesive scales to stick to the table which are basically very thin stainless steel rulers attached with strong double sided tape. I stuck them down only to find them hanging of an hour later? They simply will not stick to the painted surface? And its not because they aren't sticky, I stuck an off cut to a piece of unpainted metal with no problems whatsoever?
So my question is, has the hammerite formula changed recently? Or is it the cast iron surface? What am I missing here?
