Pultra 15/90 collet drawbar
Home Forums General Questions Pultra 15/90 collet drawbar
  • #463631
    toptigger
      @toptigger
      Hi all and hope you are all keeping safe….
      I have a Pultra 15/90 but missing the collet drawbar, I believe its the same thread used for the Schaublin W20. Does anyone know where I can get a replacement or get a Schaublin drawbar as a substitute.
      Cheers
      #27272
      toptigger
        @toptigger
        #463646
        John Haine
          @johnhaine32865
          In case you may need to make or have made a draw tube (which I think this is as the thread is on the outside of the collet), it was discussed on this forum a while back. The thread seems to be 19.7 mm OD x 1.667 pitch. (i.e. one and two thirds mm). But it's a buttress form.
          #463651
          DC31k
            @dc31k
            W20 taps are available from China on eBay (about £55).
            rcm-machines sell a W20 internally-threaded adaptor (I think it is M12 the other end). That might be a good starting point.
            #463839
            DC31k
              @dc31k
              See also this thread:-
              https://www.model-engineer.co.uk/forums/postings.asp?th=99604
              where Floyd Automatic is mentioned. On page 38 of their brochure at:
              https://www.floydautomatic.co.uk/eshop/files/files/Catalogues/Schaublin/Schaublin-Accessories-%26-Various-Items-with-Collets-Shanks.pdf
              you can buy a part-drawtube, internally-threaded W20 and external M19 x 0.75.
              #464321
              toptigger
                @toptigger
                Posted by DC31k on 10/04/2020 10:13:11:
                Yes I saw the taps and the thread adaptor from RCM, (about £25 plus £20 postage)
                …RCM adaptor probably an easier option than the tap…..very expensive postage though…
                Cheers
                #464405
                DC31k
                  @dc31k
                  Posted by simon watts on 13/04/2020 09:22:21:
                  If you can make one for less than the RCM one costs posted to you, I will take 5 please.
                  You have been provided with information that will get you a working W20 drawbar for less than £50. What were you expecting to pay for this unusual item? Good job you didn't ring Floyd Automation and ask of the Schaublin one.
                  #464614
                  toptigger
                    @toptigger
                    Posted by DC31k on 13/04/2020 15:18:12:
                    Easy tiger…..I'm just looking at options…no need to get upset about my observations about postage!!!!
                    for £50 quid this is what I get (including postage)
                    https://www.rcm-machines.com/en/rcm-production/1-nut-for-collet-w20-with-thread-s19,7-x-1,666-mm/rcgstw20
                    Its just a sleeve with a thread !!!!
                    Thank you all for your replies…..
