Silver soldering zinc plated steel
Home Forums General Questions Silver soldering zinc plated steel
  • #458408
    Rowan Sylvester-Bradley
      @rowansylvester-bradley37244
      Does anyone know whether it's possible/advisable to silver solder BZP mild steel as it is, or does one need to strip off the zinc plating first?
      Thanks – Rowan
      #27213
        #458411
        Dave Wootton
          @davewootton
          Hi Rowan
          Best to strip it off, the zinc burns off with nasty white fumes that do you no good at all, concrete cleaner does a good job of getting zinc plating off, or some drain cleaners that contain Hydrochloric acid.
          I believe there is a condition called metal fume fever that breathing in zinc smoke brings on, sounds unpleasant!
          Stay Safe
          Nick Clarke 3
            @nickclarke3
            Posted by Dave Wootton on 20/03/2020 15:43:00:
            Hi Rowan
            Stay Safe
            Take care if you smoke as this will give off inflammable hydrogen and you may discover a new way that smoking is bad for your health!
            The good news is that the used acid will probably make an excellent Zinc Chloride soft soldering flux.
            #458455
              At what temperature does the zinc burn off? I'm silver soldering at one end of a piece of BZP studding. Do I need to take all the plating off, or only within 1cm of where I am soldering, or what?
              Thanks – Rowan
              #458457
              vintage engineer
                @vintageengineer
                Malt vinegar saturated with table salt will remove zinc over night.
                #458462
                Nick Clarke 3
                  @nickclarke3
                  Posted by Rowan Sylvester-Bradley on 20/03/2020 19:06:32:
                  Thanks – Rowan
                  Don't know how much Zinc to remove in your particular situation but Zinc melts at 431C and boils at 907C but it will oxidise into very dodgy Zinc Oxide even at room temperature – heat only increases the rate of reaction
                  #458465
                    Thanks – Rowan
                    Just near where the metal gets hot. Zinc melts at about 420C and boils at about 900C, so it will misbehave at Silver Solder temperatures. The main problem is contaminating the soldered joint, so give that part a good clean. Zinc fume is an industrial hazard, not awful in hobby workshp quantities, but avoid breathing it in and keep exposure low. Work outside if possible.
                    #458474
                    duncan webster 1
                      @duncanwebster1
                      many years ago I had to arc weld some galv section together. I'd ground it off where the weld would be, but the stuff adjacent fumed off. I felt proper poorly that evening even after only a couple of hours exposure
                      #458499
                      vintage engineer
                        @vintageengineer
                        Metal fume fever can be fatal! Metal fume fever
                        #458530
                        Keith Hale
                          @keithhale68713
                          Hi Rowan
                          As I understand it, you are not welding. You are brazing with a "silver solder". Big difference!
                          See p.m.
                          I am not about to turn down my heating nor dispose of (responsibly) all the brass in my home and workshop!
                          #458754
                          David K
                            @davidk77137
                            Cup Alloys , sorry to butt in on this thread but when I click the link for your
                            HT5 Kit all I get is a Internal Server Error.
                            #458763
                              Posted by CuP Alloys 1 on 21/03/2020 09:12:55:
                              Yes, I'm silver soldering. Does this mean that I don't have to strip off the zinc? Or that I only need to strip it off the part where I am brazing? Or that I need to strip it off the whole part?
                              I guess there are two issues:
                              1. The zinc evaporating or burning with attendant health issues.
                              2. Does the presence of zinc prevent a good braze?
                              Thanks – Rowan
                              #458773
                              John Paton 1
                                @johnpaton1
                                +1 for remove the plating first.
                                Does it have to be silver solder?
                                Soft solder takes to zinc and mild steel using Bakers Fluid as flux but of course its a lower strength joint and useless for high temperature applications.
                                #458781
                                Keith Hale
                                  @keithhale68713
                                  Hi Rowan.
                                  Check your personal messages. The chances are that your brazing alloy contains a significant amount of zinc!
                                  Or email your phone number and I will ring you.
                                  Keith
                                  #458782
                                  Keith Hale
                                    @keithhale68713
                                    Hi David.
                                    Thanks for the note and apologize for the blip.
                                    I don't know what the problem is, but I will inform Glenn and Shaun today.
                                    Can I suggest that you give them a call tomorrow?
                                    Keith.
                                    #458855
                                      Posted by CuP Alloys 1 on 22/03/2020 07:23:18:
                                      There doesn't seem to be a PM. E-mail me at rowan(at)sylvesterbradley(dot)org.
                                      Thanks – Rowan
                                      #458857
                                        Does this mean that I don't have to worry about a bit of zinc in the plating damaging the braze?
                                        I'm using CuP Alloys EF Starter Pack for these joints.
                                        Thanks – Rowan
                                        #458875
                                        Keith Hale
                                          @keithhale68713
                                          Hi Rowan.
                                          Correct!
                                          Keith
                                          #458880
                                            … The chances are that your brazing alloy contains a significant amount of zinc!
                                            Keith
                                            Another thing I thought I knew for sure turns out to be wrong! I've got a convincing list of Silver Solders and very few of them contain Zinc.
                                            But Keith is right – a little research shows most modern Silver Solders contain Zinc, often lots of it. Seems my list is badly out-of-date, or maybe for some specialised industry. Can't be many hobbyists using pure Indium solder…
                                            Thanks Keith!
