Looking for 7/64 mild steel bar
Home › Forums › General Questions › Looking for 7/64 mild steel bar
  • #438194
    nigel jones 5
      @nigeljones5
      Hi – anyone know where I can get some – tried all the usual places but they only have piano wire or silver steel, but I need mild steel? Thanks
      #26969
      nigel jones 5
        @nigeljones5
        #438196
        Mike Poole
          @mikepoole82104
          If you can tolerate a deviation from dead size would 2.8mm or 12SWG wire do the job?
          #438197
          old Al
            @oldal
            even in the good old days , this size was never commercially available
            #438200
            John Haine
              @johnhaine32865
              Hmm…2.8 mm is 22 microns too big. 12 swg = 2.642 mm , 7/64 = 2.778 mm, 136 microns too small. But in BMS it was never to size anyway unless ground, often a bit smaller than nominal. Why is the size so important, can't you just use 3 mm or even 1/8?
              #438204
              Roger Clark
                @rogerclark
                These guys advertise it – EKP Supplies
                #438212
                nigel jones 5
                  @nigeljones5
                  2.8mm or 12 SWG would do the job. Its to hold together 3d printed tank tracks at 1/8 scale. Stainless would be good but as mild steel is easier for me to work with thats what I need. I use EKP as a supplier to PSB but never gave them a thought – will take a look. Thanks.
                  #438218
                    If all else fails, you will have the job of turning down some mild steel bar. Being 3mm raw material, presumably, one pin at a time close to the chuck! Looks like you are going into mass production!
                    #438233
                    nigel jones 5
                      @nigeljones5
                      Howard I think you may be correct – I hate turning long thin parts, never turns out well!
