Warco GH1224 Wiring Diagram
Home Forums General Questions Warco GH1224 Wiring Diagram
  • #26907
    Trevorh
      @trevorh
      And then it went Bang
      #433786
      Trevorh
        @trevorh
        Hi, Hoping someone has access to the wiring diagram for the Warco GH 1224 Lathe,
        Pressed the start and it went POP and the breaker tripped out, No magic smoke escaped so I am assuming for now anyway that it has suffered a dead short somewhere
        And like all owners I have the lathe up against the wall so now tonight I have to lift it clear to get access to the control box at the rear
        Luckily I have an engine hoist and chain blocks so it shouldn't be the end of the world to move it out
        I am sure it will be obvious once I gain entry to the electrics but thought it might safe a little time if I can look at the circuit first
        Trevor
        #433790
          If you have the operators manual, there should be a wiring diagram towards the back.
          If not, try contacting Warco. They will probably E mail one to you, and provide help on your problem.
          #433791
          Trevorh
            @trevorh
            Morning Howard, Yes I had the manual but it has gotten misplaced in the mists of time hence the request
            I will try warco and see
            thanks
            #433799
            John Hinkley
              @johnhinkley26699
              Judging from pictures only, the Warco 1224 bears a distinctresemblance to the Grizzly G4002 lathe. If you have no luck with Warco have a look at this, taken from the Grizzly manual. (Obviously there are differences linked to the U.S. 110V supply and there is also a manual for models produced prior to 03/14.)
              Trevorh
                @trevorh
                Thanks John, its better than nothing
                So first stop check the mains fuse, the rest is quite straight forward to follow
                cheers
                trevor
                #434269
                Trevorh
                  @trevorh
                  So first Thanks to those who helped
                  once I had pulled the lathe clear and gained access it was the main QF1 breaker that had tripped
                  I disconnected the motor and checked but it was fine
                  Checked for loose connection – none
                  Checked the loads being pulled – all fine
                  checked mechanically – all fine and free
                  so its a mystery for now
                  I reset the breaker and put the lathe back together and its running fine
                  but what worries me is that it tripped for a reason and that reason has not gone away or fixed its self so it will be back.
                  Trevor
                  #434273
                  Mike Poole
                    @mikepoole82104
                    It’s difficult and time consuming to find a fault that may not even exist so I reset and then see where we are, I have come undone on occasions, the breaker suppling an 11kW drive had tripped so I reset, the bang was deafening and it did clean the dust off the fan, we now knew that we were definitely replacing the drive so much time was saved and when you lose a car for every 55 seconds that you are down then time saved is important. Breakers do not only trip because of an electrical fault, vibration and mechanical shocks can trip them. I once had a mysterious fault tripping a 250A breaker but the load was nothing anywhere near capacity, I noticed that one of the incoming phases was rather warm and as it was below the overload heaters it was enough to trip them eventually, no damage had been caused so just tightening up cured the intermittent tripping.
                    #434276
                    Trevorh
                      @trevorh
                      Hi Mike, This is the assumption I am going with that a certain set of circumstances came to align and caused the breaker to trip, the C15 breaker is more than capable of handling the in rush and I only ever have 1 piece of kit running plus some lighting both on different circuits and protected
                      what worried me was that it also took out my main breaker for the shed that's why I was convinced it was a dead short somewhere
                      oh well just have to wait to see if it returns and if so try to deal with it
                      trevor
                      #434277
                      Trevorh
                        @trevorh
                        deleted double post
                        Edited By Trevorh on 22/10/2019 10:25:28
                        #434278
                          If it actually went ‘pop’, there was certainly something awry. Something, I would suggest, momentarily made contact with an earth potential. A chafed Live wire is most likely, I would think. Either rubbed against the case or against a an adjacent neutral conductor.. The other ’non-electrical’ fault might have been an evaporated spider or such-like?
                          #434284
                          Trevorh
                            @trevorh
                            Hi NDIY looking around it could very well have been a spider touching where it shouldn't
                            I checked all of the wires for scorch marks – not easily done in such a small control cabinet but as I say all of the wires/cables checked out fine and looked ok
                            Hope the spider enjoyed the tingle before it went pop – serves the little bugger right
                            trevor
                            #434285
                              Failure of a suppressor capacitor would explain the symptoms. The poor things are connected directly from Line to Neutral and from Line and Neutral to Earth. Although specially rated for this purpose (X and Y), they do go pop.
                              They fail by causing a short circuit, but it's only temporary because the capacitor's innards vaporise like a blown fuse. The brief short is plenty enough to cause a trip, but because capacitors usually die open-circuit everything appears normal when power is reapplied.
                              The purpose of the capacitors is to stop any Radio Frequency excrement produced by the machine being broadcast via the mains wiring. They stop the machine blotting out radio, tv and communications services.
                              It's a good theory, except John Haines' Hinkley's Grizzly Diagram doesn't show any suppression capacitors! Possibly there are some in the Control Panel circuitry.
                              Edit, silly mistake corrected thanks to John Hinkley!
                              Edited By SillyOldDuffer on 22/10/2019 11:24:53
                              #434286
                              John Hinkley
                                @johnhinkley26699
                                Dave,
                                Don't blame John Haines. That was my contribution in response to Trevor's original request as.nobody had come up with a diagram specifically for his machine.
                                John Hinkley
                                wink
                                #434290
                                Trevorh
                                  @trevorh
                                  When opening the back cover I did find this photo which shows the schematic is slightly different in that I have a couple of breakers and not a fuse or contactor
                                  #434292
                                  Trevorh
                                    @trevorh
                                    But by putting the schematic that john posted with my schematic it made it easy to understand how it had been wired
                                    so a very useful piece of information
                                    trevor
                                    #434293
                                    Trevorh
                                      @trevorh
                                      Also I couldn't see any form of suppression on any of the contactors, I have uploaded photo's of the insides in an album,
                                      unfortunately they have ended up upside down and I can't rotate them
                                      either way as usual this forum came up trumps
                                      trevor
