ACME thread identification question.
Home › Forums › General Questions › ACME thread identification question.
Viewing 25 posts - 1 through 25 (of 64 total)
  • #425906
    Nick Edgley
      @nickedgley74365
      I have a Boxford BUD lathe. I have a considerable amount of wear in the brass nut driven by the crossfeed leadscrew so decided to make a new one.
      All went well until it came to identifying the ACME thread size. Bear in mind that I am a complete novice when it comes to threads.
      I measured the thread pitch at 10 tpi. I measured the major diameter as 7/16". I ordered a 7/16" x 10 LH ACME tap. In my ignorance thinking this must be correct.
      When I tried the new tap in the existing brass nut to check that it was correct it quickly locks up, it is the correct diameter but clearly not the correct tap.
      I have a spare cross feed leadscrew, which is similar in diameter but the brass nut that is with it neither fits my original leadscrew nor does the new tap fit that either.
      I have spent many hours searching the internet and only learned that threads are an incredibly complex subject!
      I have learned that ACME threads have a 29° thread angle but that metric trapezoidal threads have a 30° thread angle. Given the age of my lathe I assumed the cross feed leadscrew would be imperial. My spare leadscrew may be metric. Either way my 7/16" x 10 tap fits neither!
      I am throughly confused and at a loss to identify the thread and order the correct tap.
      I would be grateful for any advice and suggestions.
      Thank you.
      #26803
      Nick Edgley
        @nickedgley74365
        #425919
          Welcome, Nick
          You may find some clues here: **LINK**
          http://www.boxford-software.com/spares/3656SaddleComp.html
          But hopefully one of the Boxford users will be along soon, to advise.
          old mart
            @oldmart
            Are you sure that the leadscrew is left hand? If it is left hand, looking at it, the threads will tilt slightly clockwise from vertical. Measuring the pitch can also catch beginners out, measure an inch of thread. There should be ten pitches from the start of the first to the start of the tenth. I would think that Boxford would either use 10tpi or 8tpi, assuming the lathe is imperial and not metric.
             Don't worry about the ACME being 29 degrees and the Trapezoidal being 30 degrees, you will not be able to tell the difference.
            Edited By old mart on 25/08/2019 13:25:02
            #425927
              As you noted, trapezoidal (a metric thread) is quite different to an ACME (imperial thread). While your lathe may well have an imperial dial on the cross feed, you need to check the travel, for a few turns, with a dial gauge. 2.5mm is quite close to 10tpi and one can never be sure if the lathe has been modified. Home turned feed screws are most definitely not unheard of.
              #425929
                Nick,
                May I suggest that you post a few photos of the items in question ?
                You may be sufficiently enlightened to instinctively know how to do that on this forum … But if, like many newcomers, the process eludes you: Try reading this **LINK**
                https://www.model-engineer.co.uk/forums/postings.asp?th=103028&p=1
                old mart
                  @oldmart
                  When the exact pitch is in question, then using a longer reference length will give more accurate results. For instance, the difference between 8tpi and 3mm pitch is only about 0.007", which would not be easy to measure over one pitch. Not so difficult if measured over 300mm, (100 X 3mm), or 12", (96 X 8tpi).
                  #425937
                    Welcome to the forum Nick,
                    Might be some helpful hints here:
                    http://www.model-engineer.co.uk/forums/postings.asp?th=87079
                    Which suggests your measurements are correct.
                    Pete Rimmer
                      @peterimmer30576
                      Your problem might simply be a matter of the wear in the nut having caused burrs that the worn screw rides past but the new tap does not.
                      Measure twenty threads on the screw. If it's 50mm you have a metric screw, if it's 50.8 (or 51 to a steel rule) then it's an inch screw. Inch screws are 7/16" x 10TPI LH
                      #425942
                      old mart
                        @oldmart
                        I have looked up the thread calculator, and the standard bore through an ACME nut of 7/16" by 10tpi, is 0.343". The tip of your tap should be this diameter or a little less. To verify your pitch measurements, the scale on the leadscrew handle should be 0-100 in thousandths of an inch. Holding the two leadscrews alongside each other will confirm whether the pitches match.
                        https://www.engineersedge.com/hardware/acme-threads-calculator.htm
                        I don't know how to get a link to work on this forum.
                        Edited By old mart on 25/08/2019 15:04:46
                        #425944
                        Clive Foster
                          @clivefoster55965
                          Further to the suggestion from old mart about measuring a longer length of thread to get more accurate results. Probably essential when dealign with unknown amounts of wear and unknown tolerances.
                          Given that such imperial / metric feed screw confusion is only likely where the pitches are very similar the best method is to use a length corresponding to half a pitch difference. Doing things that way it becomes a simple ruler job. On one thread the specified length will be between the same sides of the thread whilst on the other it will be between opposite sides. Easily seen. Distance doesn't have to be terribly exact. Within three or four threads either way will usually do.
                          For example comparing 10 TPI with the very similar 2.5 mm pitch we find that 3.1" of thread covers 31 pitches of 10 TPI and 31.5 pitches of 2.5 mm. Going the other way and comparing 2.5 mm pitch with 10 TPI we find that 80 mm covers 32 pitches of 2.5 mm and 31.5 pitches of 10 TPI for all practical purposes. Actually 80.010 mm but the odd 0.010 mm is hardly relevant.
                          Comparing 8 TPI and 3 mm as suggested by old mart we find that 1" of thread covers 8 pitches of 8 TPI and 8.5 pitches of 3 mm, (1.004" actually). Going the other way 27 mm covers 9 pitches of 3 mm and 8.5 pitches of 8 TPI (26.988 mm actually).
                          Fairly easy spreadsheet calculation if you are computer savvy. I've done the calculation and comparison exercise three time now. If I ever have to do it again I shall spend some time drawing out the thread pitches as a set of side by side bars giving me an instant comparison ruler. Obviously only good for feed screws and similar coarse pitches but they are the ones where the ordinary inch or so long thread gauges run out of resolution.
                          Edited By Clive Foster on 25/08/2019 15:10:11
                          Edited By Clive Foster on 25/08/2019 15:11:13
                          Edited By Clive Foster on 25/08/2019 15:11:47
                          Edited By Clive Foster on 25/08/2019 15:30:20
                          #425947
                            Posted by old mart on 25/08/2019 15:02:56:
                            #425957
                            old mart
                              @oldmart
                              I needed a crosslide leadscrew and nut for the Smart & Brown model A at the museum, and bought a new leadscrew with two nuts which was long enough to modify for the lathe. It was advertised as 8tpi, but turned out to be 3mm pitch. I told the vendor, who immediately refunded my money and said keep it. It was one of those times when hard choices have to be made. Keep looking for a hard to get item, or make the most of what you have got. I used the leadscrew, and also used both nuts for an adjustable backlash feature. On an old imperial lathe, a metric leadscrew is not a good idea, so I used the rotary table on the mill to make a scale for the crosslide with 118 divisions instead of 125. The actual error is tiny, especially if you creep up on the last bit of the size required. The backlash is set at 0.001", which makes for smooth running.
                              #425968
                              Gary Wooding
                                @garywooding25363
                                Here's how I insert a link into a posting.
                                Copy the URL of the link you want, either by writing it down or using the Windows COPY facility (ctl+C).
                                Then click the LINK icon above to bring up link window and enter the information required. When you click OK the link data is saved t the cursor position.
                                **AnyThing***
                                #425973
                                old mart
                                  @oldmart
                                  Not quite the exact topic, but worth bookmarking:
                                  Thanks for the the instructions on how to post links, I will try to remember how.
                                  Edited By old mart on 25/08/2019 18:21:30
                                  #425976
                                  DC31k
                                    @dc31k
                                    Can you describe the graduations on the cross-slide dial please. How far does the cross-slide move when you rotate the wheel one turn? Take a marker pen and trace round the crest of the thread and tell us what you see.
                                    There is a possibility it could be 5tpi two-start.
                                    #425988
                                    Pete Rimmer
                                      @peterimmer30576
                                      The drawing calls for 7/16"-10 LH so that's surely what it will be.
                                      #425990
                                      Nick Edgley
                                        @nickedgley74365
                                        Thank you all very much for your rapid and comprehensive replies.
                                        I will need to spend some time investigating all of your suggestions and links. I am away from home until Tuesday but when I get back I will post some comprehensive photographs of the two leadscrews in my possession.
                                        #425996
                                        Clive Brown 1
                                          @clivebrown1
                                          I've owned 2 Boxfords, both imperial, one of them from new. Both have 7/16" x 10 tpi LH single start feedscrews.
                                          #426009
                                          old mart
                                            @oldmart
                                            What condition is your spare leadscrew and nut? Could it be used? I recently made a new 3/4" x 5 Acme nut for a mill, and bought a tap from Tracy Tools. When I tried a test thread in aluminium, I realised there was very little chance of tapping the thread without a tap wrench with a 3 foot long handle. The tap was about 8" long with a gradual taper, and I had to shoehorn a smaller acme insert on a special threading tool just to partially produce the thread for the tap to finish, and then it was hard work. This was in leaded bronze (gunmetal).
                                            Do try a test piece before the actual nut, you may have to tap into a slightly oversize hole. Keeping the tap straight could be made easier using a dead centre in the end of the tap, with the nut in the chuck, preferably a 4 jaw independent.
                                            #426019
                                            thaiguzzi
                                              @thaiguzzi
                                              Metric threads were 2,5mm pitch, imperial were indeed 10TPI.
                                              My Boxford, a 69 VSL, has an imperial leadscrew and gearbox but metric cross and top slide screws and dials.
                                              Stock, from the factory….
                                              That is another give away – what dial do you have?
                                              #426553
                                              Nick Edgley
                                                @nickedgley74365
                                                Mystery is solved!
                                                I carefully read all your very useful suggestions and information.
                                                I drilled and tapped a piece of scrap aluminium and it fitted comfortably on my spare lead screw which confirms that the spare is imperial. I am still a little puzzled that my 7/16" x 10 ACME tap doesn't seem to fit the existing brass nut on this leadscrew.
                                                Using the tip above from Pete Rimmer the measurements he gave confirmed the spare leadscrew as imperial and the one on my lathe with the worn brass nut as metric. This also explains the graduations on the cross slide dial which are numbered 0, 0.5, 1, 1.5, 2.0, 0 with 50 graduations between each number (a total of 250 graduations). Unfortunately I do not have the imperial cross slide dial, only the leadscrew and nut.
                                                What tap do I need to cut a metric thread to match the metric leadscrew? I presume it is a trapezoidal tap but the sizes confuse me and they also seem quite expensive compared with the imperial ACME tap I have already purchased.
                                                Imperial leadscrew (my spare):
                                                Metric leadscrew (in use and worn nut):
                                                Cross slide dial:
                                                #426561
                                                Pete Rimmer
                                                  @peterimmer30576
                                                  What tap you need depends on the diameter of the screw. Hopefully it'll be 12mm then you'd need a TR12 x 2.5 LH (Trapezoidal, 12mm diameter, 2.5mm pitch, Left Hand) tap.
                                                  However, there's no rule to say it has to be an ACME thread. For instance the Denford lathe, a close relative of the Boxford range (they were once the same company) uses a cross slide screw which is 1/2" diameter, 2.5mm pitch and neither ACME Nor Trapezoidal thread form but "modified square section" thread.
                                                  I'd try to find a drawing for the screw or the nut.
                                                  #426565
                                                  Diogenes
                                                    @diogenes
                                                    Hi Nick
                                                    Hope that this doesn't read like there is an "granny egg-sucking" element here – apologies if so..
                                                    If it's a standard LH Metric trapezoidal thread with a pitch of 2.5mm, then the only other dimension that you need to establish is the major diameter – I'd expect it to me a whole number integer (perhaps 11 or 12mm?) – measure across the widest part of the least-worn part of the thread.
                                                    The designation of the tap would then be something like "TR LH 11×2.5" or "TR11x2.5LH", where the "11" represents the major diameter of the thread and the "2.5" the pitch.
                                                    IF the diameter is not a whole number in millimetres, then it is possible that the screw is a "bastard" size and some checking with Boxford owners will be necessary.
                                                    To throw in couple of general observations, suitable taps from UK suppliers do seem inordinately expensive if you only intend to do this one job with them. I'm sure that something direct from the Far East will be available at a fraction of the price, and I, personally, wouldn't completely discount their usefulness for a one-off job in bronze. As you already did, I would also drill & tap a test-piece in order to check the fit first, whatever the source.
                                                    Having said all of that, I note that in the link that Michael Gilligan provided in the first reply you had to the original post, a Metric feedscrew nut seems to be available for about £60 – (is this the correct part? ..I've never been that intimate with a Boxford) ..considering the costs in tooling. materials, and time, I wouldn't hesitate to buy the spare part – and there's certainly no shame in buying what is, after all, a consumable service item. On the other hand I do recognise the challenge & satisfaction of a completely owner-executed repair, in which case I hope it goes well.
                                                    #426572
                                                    Pete Rimmer
                                                      @peterimmer30576
                                                      The Reltub guy who sells them on eBay quotes the size as 7/16" x 2.5mm ACME which is a bit unfortunate but not surprising IF he's correct about the ACME thread form. As I said above Denford used ACME for the imperial screws and modified square for the metric.
                                                      I'd be tempted to use the imperial one and suffer the 0.04mm-per-turn error for now until a metric replacement pops up. It's no worse than having the tool off centre height on a small diameter and much less than a badly worn screw.
