O RING
O RING
Home Forums General Questions O RING
  • #312350
    Phillip weaver
      @phillipweaver84697
      WHEN USING A O RING THAT'S 1"X3/4X1/8 HOW DEEP DO YOU MAKE THE RECESS
      Edited By JasonB on 16/08/2017 19:48:03
      #25446
      Phillip weaver
        @phillipweaver84697
        USING A O RING
        #312386
        Dave Halford
          @davehalford22513
          You type o ring clearance into google
          smiley
          #312387
          mechman48
            @mechman48
            Dave beat me to it !
            ​Geo.
            #312391
              Problem is you will probably get an industrial standard from google, for model work the sizes are different so that teh ring is compressed less which makes for an engine that turns over more easily.
              Assuming you want the groove in a piston then groove depth is 0.132" and width 0.166" wide.
              SAE would be 0.124" deep and 0.188" wide which makes things a lot tighter but is meant for pressures upto 1500psi
              Edited By JasonB on 16/08/2017 20:37:59
              #312396
              HOWARDT
                @howardt
                What is the o ring being used for, is it static or dynamic, pressure, operating medium.
                #312397
                vintagengineer
                  @vintagengineer
                  Also you need to keep clearances as tight as possible to stop the O ring being extruded into the gap. If it is being used for high pressure you use back up rings.
                  #312398
                  Russell Eberhardt
                    @russelleberhardt48058
                    It's well worth getting a copy of Tubal Cain's Model Engineers Handbook. That gives the appropriate figures for various sizes of O-rings and the ideal profile of the groove for various applications. Lots more useful information as well.
                    Russell
                    #312479
                    Phillip weaver
                      @phillipweaver84697
                      Thanks All for your replies. I am making a model of VICTORIA Steam engine and its my first go A real ham HI HI its coming along nicely building from scratch no casts that way I will learn a lot more . And Russell I will get a copy of Model Engineers Handbook
                      #312484
                        In that case the sizes I gave will do just fine as I took them out of said book.
