Posted by James Steele on 24/07/2017 17:31:07:
Also i am not sure if i have enough room for a hoist to fit in my shed.
thanks Jimmy
When I bought a bigger lathe I found that I'd miscalculated by 200mm the space needed to maneuver the engine crane plus lathe inside my garage. As a result it was difficult to get the lathe up against the wall as planned. Needing time to think, I plonked the lathe down at right-angles to the wall instead. By happy accident this position gave much better access for gear changes, so I've left it where it is.
However, I did get useful suggestions from the forum about moving heavy objects in tight spaces: basically some combination of rollers, levers, wooden blocks, and perhaps a jack. The rollers can be lengths of pipe.
Perhaps someone who has actually done it could provide more detail. I don't believe it's difficult, just sweaty and time-consuming compared with using a crane.
Edited By SillyOldDuffer on 25/07/2017 08:55:36
