GH Universal
GH Universal
Home › Forums › General Questions › GH Universal
  • #308538
    James Steele
      @jamessteele69365
      HI all looking for help
      I finally decided on my new milling machine its a waro gh universal square column.My problem is that i am not sure where to put the straps of the engine hoist.Also i am not sure if i have enough room for a hoist to fit in my shed.If i need to dismantle the mill is it straight forward taking the head off.Any ideas or tips would be greatly appreciated
      thanks Jimmy
      #25386
      James Steele
        @jamessteele69365
        lifting machine
        #308546
        Oldiron
          @oldiron
          Hi Jimmy. Usually the user guides that come with heavy machinery have lifting instructs in them. If not contact Warco direct they will be happy to tell where to lift it. Not too sure on removing the head but usually running it right down to the bottom of the ways should get it below the top of the column and give minimum height. Then its probably easier to remove the motor if it is above the column top. The thing to remember is if you take the head off do you have the height to put it back on when its on the bench or its stand.
          regards Gary
          #308549
          I.M. OUTAHERE
            @i-m-outahere
            Basically the same as my hafco mill , wind the y axis all the way in lower the head as far as possible and sling it up aroung the head swivel bracket as close to the column as you can get it , use the x axis movement to balance it up so it hangs straight
            If you want decent manuals for it try thry the grizzly website .
            #308572
            Bill Davies 2
              @billdavies2
              Hi, James.
              After doing what XD says above, I lifted mine with flat fabric straps around the circular part between the head and the vertical slide, where the protractor strip is mounted. I left the motor in place. I had my son to hand to stop the mill from swinging about on the cable, and carefully positioned it on a wooden stand. Take it easy, it is very heavy, although perhaps less intimidating to those already accustomed to moving machines or engines.
              Regards, Bill
              #308576
              James Steele
                @jamessteele69365
                Thanks for all the help
                I will get a friend to help and give it a go tomorrow
                Jimmy
                #308640
                  Posted by James Steele on 24/07/2017 17:31:07:
                  thanks Jimmy
                  When I bought a bigger lathe I found that I'd miscalculated by 200mm the space needed to maneuver the engine crane plus lathe inside my garage. As a result it was difficult to get the lathe up against the wall as planned. Needing time to think, I plonked the lathe down at right-angles to the wall instead. By happy accident this position gave much better access for gear changes, so I've left it where it is.
                  However, I did get useful suggestions from the forum about moving heavy objects in tight spaces: basically some combination of rollers, levers, wooden blocks, and perhaps a jack. The rollers can be lengths of pipe.
                  Perhaps someone who has actually done it could provide more detail. I don't believe it's difficult, just sweaty and time-consuming compared with using a crane.
                  Edited By SillyOldDuffer on 25/07/2017 08:55:36
                  #308722
                  James Steele
                    @jamessteele69365
                    Thanks or all the suggestions
                    I ended up dismantling the mill into managable pieces and my friend and i got it installed
                    tomorrow i will tram it in and make some chips
                    Jimmy
