Xmas in the workshop/shed
Home › Forums › General Questions › Xmas in the workshop/shed
Viewing 25 posts - 1 through 25 (of 45 total)
  • #273307
    sean logie
      @seanlogie69385
      Who's going to be turning/creating over the festive ,I'm off for two!!!!! whole weeks ,should be enough time to cut the threads in my back plate for the 4 jaw ….
      #24954
      sean logie
        @seanlogie69385
        #273311
        Steven Vine
          @stevenvine79904
          I've got a week off. l Hope to make some progress and move the new workshop along a bit. I'm still at the build benches stage. I've been without it for a year.
          I only hope Macdonalds is open Christmas day, so I can get some fast food, to save any hold ups.
          Steve
          #273313
          Brian Oldford
            @brianoldford70365
            Take your time to make a very accurate dummy nose piece first concentrating on the register diameter. The thread in the new backplate may benefit by being a little sloppy to allow the backplate to centre repeatedly on the concentric register IYKWIM.
            #273314
            John Rudd
              @johnrudd16576
              Macdonalds….?? For a christmas meal?……
              I wouldnt feed it to the dog……
              KFC is my choice for fast food….
              Anyway whatever delectable delights you select, enjoy……
              #273316
                Last finishing touches to a kitchen I have been doing and then pop into a regular client for a quick dod job, should be done by lunchtime then I'm off for two weeks.
                Will no doubt spend a day or three in the workshop working on the R&V and Ruston Hornsby engines and may be tempted to make a start on something else. Also got a package from ARC sitting under the tree.
                J
                #273318
                Mark C
                  @markc
                  If I ever get done with work projects , I have all my material lined up for a bass drum pedal I want to build! Should only take a day or so but there is the small matter of freeing up machine space from other jobs to be dealt with first…
                  Mark
                  #273322
                  Scrumpy
                    @scrumpy
                    I'm with you kfc for me. I hope to light my allchin for a steam up on Boxing Day and if I had been a bit more prepared I would paint the gear covers on my fowler showman but I seem to have lost the paint colour chart if any one has any idea maroon or black it would help as the alternative is tv and I don't fancy that , Christmas greetings to you all and thanks for all the help and advice I've been given this last 12 months
                    #273323
                    JA
                      @ja
                      Last afternoon in workshop tomorrow and then straight back in after Christmas as soon as it is slightly warm. I have to finish the manufacture of a large number of small square nuts and square headed bolts.
                      Have a good Christmas everyone.
                      JA
                      #273324
                      Anonymous
                        I expect to have some workshop time, and have planned the following:
                        Annual megaclean and oiling/greasing of machine tools
                        Find out why the guillotine is hiccuping, and fix it
                        Swap the surface grinder and shaper, and extract the broken drive arm from the shaper so I can repair it
                        Visit A&E after doing mysefl a mischief extracting the shaper drive arm
                        Make a collar to attach the high speed milling spindle to the CNC mill
                        Screwcut some adaptors for the dead weight pressure tester and experiment with making Bourdon tubes
                        Drink port with cheese and biscuits
                        #273325
                        sean logie
                          @seanlogie69385
                          Posted by Brian Oldford on 22/12/2016 18:30:42:
                          I have material in the lathe waiting to make a dummy nose thread and register as wee speak . yes
                          #273328
                          Nick Wheeler
                            @nickwheeler
                            My plans are some basic tool maintenance, and diagnosing why my good drill chuck no longer self ejects from the tailstock. A bit of a clearout in the garage is probable
                            I might make a start on some tool sharpening stuff.
                            We're not working next week, but there's another pair of jacks that need to be lower so I'll probably cut them down and make the trolley for the compressed air cylinder a bit safer to use.
                            In between all of that, we've a number of quarter peals and other ringing arranged
                            #273329
                            Chris Evans 6
                              @chrisevans6
                              Swamped with motorcycle and petrol engine radio controlled car (Buggy things) work for others to make much progress for myself. Four or five days should clear up most of the bits, radio control man can wait. Then on to some long planned work on my pre war bike.
                              #273332
                              MW
                                @mw27036
                                Posted by JasonB on 22/12/2016 18:36:02:
                                J
                                It isn't the new Tomé fetiera files? no kidding that's what's under mine..yes
                                Michael W
                                #273335
                                Harry Wilkes
                                  @harrywilkes58467
                                  Posted by Steven Vine on 22/12/2016 18:28:15:
                                  Steve
                                  Steve dont know about a Big Mac on Christmas but my local pizza house is open on Christmas day yes
                                  H
                                  #273353
                                  AndyA
                                    @andya
                                    I've got a set of rolls which need turning and a front fork to finish.
                                    #273356
                                    julian atkins
                                      @julianatkins58923
                                      I have done some of my best and most inventive work over xmas in years gone by.
                                      The in laws would be staying over, and I would escape to the shed, after cooking xmas dinner for all.
                                      This xmas I have 6 miniature injectors to sort out for friends.
                                      Hope you all have a super xmas!
                                      Cheers,
                                      Julian
                                      Edited By julian atkins on 22/12/2016 23:21:01
                                      #273357
                                      Danny M2Z
                                        @dannym2z
                                        Not quite in the workshop, I'm off to the mountains with my fly rod and a box of home tied trout flies as it's forecast to be 100° + for the next week down here.
                                        Rocky Valley dam, Pretty Valley dam and the Upper Murray (Indi) are much more cooler options.
                                        All have safe and merry Christmas whatever you do.
                                        * Danny M *
                                        #273363
                                        Chris Barry
                                          @chrisbarry
                                          I'm off for Christmas and boxing day, if i venture into the workshop other than to retrieve SWMBO presents I'll be in more than the dog bowl, but her dad has just bought a schuablin 13 whichI.im going to make packing pieces for the Harrison tool post on around new year.
                                          Whilst also stripping his Tinkerbells boiler ready for steam test and other general winterising jobs.
                                          Edited By Chris Barry on 23/12/2016 00:50:10
                                          #273368
                                          John Stevenson 1
                                            @johnstevenson1
                                            Sod the workshop, I do this all year for a living, nice to have 5 days off to play with the Delectable Debs.
                                            Mind having said this she is low on one of her products that she sells so probably go in for 3/4 of a day and run the CNC lathe, that should get stock levels back up a tad.
                                            #273370
                                            pgk pgk
                                              @pgkpgk17461
                                              At least this thread has cleared up the question of who is responsible for the plague of fast food outlets (and probably coffee places) in my fair country. My only trips into McD are 'cos they have clean toilets.
                                              Personally I made up a huge saucepan of stew: onions, mushrooms, jalopeno peppers, leeks, carrot, cabbage, peas, sweetcorn, diced steak etc: Good for 3-5 days in the fridge and microwave as needed……and i'd take a thermos of coffee rather than pay silly prices…
                                              Curry houses I'll accept… and the better quality Jamaican takeaways if you can find one doing a good jerked pork or curried goat.smiley.
                                              Now to battle with a 300-mile round trip to check on my bedridden 98yr old mum and take stuff for her carers…
                                              #273376
                                              Martin Connelly
                                                @martinconnelly55370
                                                Following on from their world record success with the Warhorse monowheel **LINK** the UK Monowheel team are making a new wheel named Trojan. So I have started making parts for it and will be getting some work done over the next few weeks.
                                                Martin
                                                #273392
                                                Russell Eberhardt
                                                  @russelleberhardt48058
                                                  Posted by pgk pgk on 23/12/2016 06:35:31:
                                                  Same here, even in China and, perhaps more surprisingly, in Francewink
                                                  For me, Christmas morning cooking a British style Christmas lunch. Then drinks on the terrace in the sun. Then Skype call to the grandchildren in the afternoon.
                                                  Boxing day lunch in the mountains for a white Christmas then perhaps some workshop time on Tuesday.
                                                  Joyeux Noel à tous
                                                  Russell
                                                  #273396
                                                  Gordon W
                                                    @gordonw
                                                    Never plan to do anything, 'cos you will be disappointed. Here in N Scotland have been looking round for stuff that might blow away, got the tractor shed tied down to the tractor, so should be ok. Will be happy when the storm passed and the new roof is still on. I have a bookshelf to finish then get tidied , then back to the hot-air engine that I have not seen for weeks. Beef rib for xmas. Fast food ? bah. Off to pub this lunchtime, need to check holiday openings.
                                                    #273444
                                                    sean logie
                                                      @seanlogie69385
                                                      That's me on hols for 16 days ….. wink 2. Went in to our local hardware store on way home from work and discovered they sell tooling for metal lathes , result i thought !! …. until i read their prices holy mother of …. They were selling a 10mm insert tool holder for £98 ,packets of 5 cnmg inserts for £60 !!! ,small boring bars for £70 …. way too rich for me .
                                                      Merry Xmas
                                                      Sean
