Huan yang inverter
Huan yang inverter
Home › Forums › General Questions › Huan yang inverter
  • #24494
    Robonthemoor
      @robonthemoor
      potentiometer
      #234439
      Robonthemoor
        @robonthemoor
        I have a 4 kW huan yang inverter and I want to know what size potentiometer in watts I need for it? Also what size would I need for the same make inverter for a 2.2kw inverter? I have the instruction book but can't find the information. Many thanks Regards Rob & Al. Manufacturer Hong Kong Y & F Group Ltd
        #234450
        John Rudd
          @johnrudd16576
          Page 12, you need a 10 k linear pot, or 10 k B. Wattage wise a standard linear pot from Maplin will do you….but make sure it is linear or the speed control wont be right……
          Same pot btw, for either inverter…..
          #234496
          Robonthemoor
            @robonthemoor
            Al' did see that on page 12 but I though it ment a resistor, my fault, thank for the info & a quick response. Regards Rob 👍
