Rebuild after a major crash two weeks ago
Home Forums General Questions Rebuild after a major crash two weeks ago
  • #130732
    Windy
      @windy30762
      After my last tethered hydroplane flash steamer major crash at the Midland Area Championships two weeks ago and burning gallons of midnight oil I just managed to get it in a state to run at Kingsbury on 22 September 2013.
      A fellow competitors video shows what happened
      http://www.youtube.com/watch?v=MqqOTd32sig
      Despite a leaking cylinder head and a faulty prop shaft plus cam timing needing altering it still managed 122mph plus.
      With Bob Kirtley on form it was a close competition with fractions of a second between our times.
      A very enjoyable end to my season.
      Paul
      Edited By Windy on 26/09/2013 00:50:57
      #22859
      Windy
        @windy30762
        #130739
        jason udall
          @jasonudall57142
          Marvelous.
          Great come back.
          ..just how much work for say 10% improvement ?..
          #130743
          Alan Jackson
            @alanjackson47790
            What an exiting run, well done
            Alan
            #130750
            richardandtracy
              @richardandtracy
              Wow.
              I really never even dreamt that was possible.
              Richard
              #130759
              Ian S C
                @iansc
                Jason I'd say it would be worth many hours to get 1% improovement, 10% is a massive change.
                Congratulations Paul,………. next season!!! Ian S C
                #130772
                Sub Mandrel
                  @submandrel
                  Well done Paul, and congrats again on the July record.
                  Boiler Bri
                    @boilerbri
                    Omg that was good to watch. I have watched northern amp draggers at Bridlington model boat club and there fast but nothing like that.
                    Nice jobmatey
                    bri
                    #130784
                      Amazing performance, Paul
                      It's very different technology, but you might enjoy this.
                      … Two Oracle "Americas Cup" boats practising.
                      Edited By Michael Gilligan on 26/09/2013 22:13:55
                      #130801
                      KWIL
                        @kwil
                        Interesting "pattern" in the wake behind with the peaks of water (vertical) which I presume corresponds with the prop tips as it turns?
                        #130809
                        Ian S C
                          @iansc
                          OOPS, we did'nt quite make it, but apart from an Aussy, English man, most the rest seem to be Kiwis on Oracle, oh and 1 American.
                          The latest I'v heard in NZ, that some Oracle crew that were ditched early are (maybe)going to court over the technoligy of the boat. The NZ syndicate is having nothing to do with this. Ian S C
                          #130840
                          jason udall
                            @jasonudall57142
                            ..what I meant earlier
                            How much work for extra 10%.. was after the crash and what must have been a very time constrained rebuild..to come out with only a estimated 10% loss is remarkable ..and yes that further 10% would probably take many times as long. .
                            Again remarkable comeback..
                            #130844
                            Sub Mandrel
                              @submandrel
                              It is wholly remarkable. The video just looks too fast to be real!
                              Windy
                                @windy30762
                                Thank you for your comments after the event Bob phoned to tell me on his final run his piston seized in a bad way his hydro and my own were running extremely hot.
                                We discussed why a possible cause because pump valve lift had increased through wear the 0.014" lift had increased that has an effect on water delivery?
                                This weekend I hope to do a static test in a pond to try some alterations.
                                A dyno would be handy but it would be difficult to simulate conditions on a run due to so many variables.
                                Jim Bamford tried one **LINK**
                                Paul
                                #130899
                                Ian S C
                                  @iansc
                                  Paul, that's an interesting link. Ian S C
                                  #130901
                                  Sub Mandrel
                                    @submandrel
                                    HI Paul,
                                    A very interesting link.
                                    I've seen the wind tunnel in a shed door in an old ME.
                                    Windy
                                      @windy30762
                                      I had an interesting day at Bob Polleys railway track with the York and Pickering Model Engineer Clubs being invited.
                                      A test firing with the Flash steamer in his small pond was a bit hair rising for me.
                                      With the nose of the hydro embedded in the bank then raising the propeller up and down in the water to check how the engine performed.
                                      A welders leather gauntlet was worn to hold the hydro’s stern as it gets very hot plus safety goggles as I did not know what to expect doing a static test for so long.
                                      As I could not simulate the air speed at 120mph the burners cooled off after a while but noticed at one speed range could feel an oscillation on the rear I think it was the prop shaft as it had been straightened prior to my last meeting and was not too confident about it.
                                      With duck weed flying it answered a few queries now back to making some new parts for it.
                                      Thanks Bob for an interesting day.
                                      Paul
