Hi, I think my best summit for nowt that I've ever had (financially that is) is my garage/workshop. It started off with the floor which was an old loading ramp for fork trucks to load up containers which are carried on lorries and also those big container type lorries. It got scrapped because the insurers would not insure it because the supporting structure was in need of serious repair which would have cost more the a new lighter duty and manoeuvrable one.
Even had free use of transport to bring it to site. The pad of concrete was free and delivered as well. The framework was next, which was a disused and rather tiered old mess room that lived it's life in a quarry.
The semi-circle angle irons originally held the roof on, which was corrugated iron. If you look at the picture closely you can see the sides were made of four frames, two each side bolted together but I had to set them apart to match the length of the floor. I had to replace all the joining plate along the bottom as they had well rusted away and also made new plates to hold the new roof angles on. There is another picture in my general photos album which show the side more clearly for those who are interested. The semi-circle angles are used here manily to carry the runners for my lifting gantry.
The sheeting covering the final framework was also free, as by the time I got to this stage there was a lot of scrap sheeting removed from a processing plant, due to corrosion where the were fixed to the purlins. Also had some metal window frames given me as well. The only major thing I had to buy was the paint.
Regards Nick.
Edited By David Clark 1 on 24/02/2013 10:32:04
