Drilling a hole through Keyless chuck
Home Forums General Questions Drilling a hole through Keyless chuck
  • #95862
    Ian P
      @ianp
      I have a unused 1/4"-6mm 'Supra' Rohm drill chuck which I want to 'improve' by drilling a 1/4" hole all the way through. At present the jaw opening and the fixing ends are both blind.
      The jaw section of the chuck has a very shallow depth and only grips the top 15-18mm of the drill. Its fine for most drills but I want to hold a (usually double ended) Slocumb bit so only the tips of jaws really come into play.
      The part I want to drill is very hard but I am hoping it will succumb to a carbide drill so I need to dismantle it first. Does anyone know how easy it easy to dismantle a Rohm chuck?
      Ian
      Edited By Ian Phillips on 06/08/2012 21:41:35
      #22172
      Ian P
        @ianp
        #95865
          I would have thought its easier to cut one end off the centre drill than modify the chuck or if it's just for starting a hole use a spotting drill.
          J
          #95866
          Ian P
            @ianp
            You may be right Jason! After my posting I Googled to see if I could find a 'Teardown' video on youtube, I didn't, but I did see a cross section view and it looks as if this type of chuck has a central 'Leadscrew' so my drilling would have nicely wrecked it.
            Ian
            #95900
            Lambton
              @lambton
              What you are trying to drill through is the hardened thrust plate which works against the inner ends of the jaws and is operated by the rotation of a screwed sleeve. I do not think you will have much luck and if you do manage to drill through the thrust plate you will probably ruin a good chuck.
