Hemingway spindle speed increaser
Home Forums Workshop Tools and Tooling Hemingway spindle speed increaser
  • #19299
    lfoggy
      @lfoggy
      #403522
      lfoggy
        @lfoggy
        There was a thread back in 2011 about the spindle speed increaser designed by Dick Stephen and sold as a kit by Hemingway. There was some discussion about limitations of the design but it seems nobody had actually completed one. Has anyone built one since then? I have just started building one and am hoping to use it for slot mills 2mm in diameter. I am not sure how rigid it will be though as it is of lightweight design and relies on just a plain bearing at the top.
        #403529
        John Haine
          @johnhaine32865
          Will your mill run in reverse?
          #403537
          lfoggy
            @lfoggy
            Fortunately my mill does run backwards.. i realise this is an issue for some machines.
            #403569
            Nick Hulme
              @nickhulme30114
              My FB-2 will run in reverse, great for reversing out taps etc. but since the oil pump is a helical screw connected to the motor shaft you wouldn't want to run it in reverse for any length of time.
              I built a belt drive speed increaser for engraving and micro-machining, it cost me an afternoon and about £15.
