DTI Right angle lever
Home › Forums › Workshop Tools and Tooling › DTI Right angle lever
  • #367241
    Rod Ashton
      @rodashton53132
      Hi – Could anyone offer a source of supply for one of the right angle pivoting arms, that transfer the movement of a plunger type DTI through 90 deg. Used to have one but lost it??
      #19039
      Rod Ashton
        @rodashton53132
        #367264
        Martin Connelly
          @martinconnelly55370
          Starrett item 671, universal attachment.
          Martin C
          #367278
          roy entwistle
            @royentwistle24699
            I wouldn't have thought it would be difficult to make one
            Roy
            #367281
            Martin Connelly
              If you want to use it as a comparator then it is not too hard. If you want accurate figures the two lever arms need to be the same length at all angles. This makes it a trickier problem.
              Martin C
              #367286
                Posted by roy entwistle on 14/08/2018 10:55:22:
                Issue 1 of MEW had an excellent four-page article on that very subject.
                Ian S C
                  @iansc
                  I made one years ago, its a rather rough and ready bit of scrap iron, but it works.
                  Ian S C
