nvr?? switch
nvr?? switch
Home Forums Workshop Tools and Tooling nvr?? switch
  • #18722
    mark smith 20
      @marksmith20
      #324261
      mark smith 20
        @marksmith20
        Hi,
        I have this dismembered Perform brand  cheap wet and dry grinder ,im wanting to use it just to attach some diamond 6" flat lapping discs i have . Problem is the switch has decided to stop working.
        It powers on but as soon as you take your finger off the start switch it stops.
        I was wondering if this is the right switch from axminster?? is there cheaper anywhere?
        dimensions of cut out are slight less on the axminster replacement .The original switch is around 42-43mm x 27mm. There is nothing written on the broken switch . The grinder is 250 watts.
        Edited By mark smith 20 on 29/10/2017 13:50:31
        Edited By mark smith 20 on 29/10/2017 13:56:25
        #324268
          The last NVR switch I bought was from an epay seller. I didn't buy the cheapest available, but it was less than that one. Works OK.
          #324271
          Frances IoM
            @francesiom58905
            I’ve used the Axminster switch on a grinder without problem – it used to be quite a bit cheaper when I bought it – you can certainly get ones with the same (?standard) fitting for about half that price – often these cheaper models have the additional feature of a link that allows wiring in other safety switches eg gear covers in lathes
            #324276
            mark smith 20
              @marksmith20
              Thanks for the replies so the specs on the axminster one will work fine on the 1/3hp grinder ??
              #324279
              Nicholas Farr
                @nicholasfarr14254
                Posted by mark smith 20 on 29/10/2017 15:16:08:
                Hi Mark, yes, provided that you don't have an emergency stop or other fail safe switches to wire in.
                Regards Nick.
                Edited By Nicholas Farr on 29/10/2017 15:39:14
                #324280
                John Rudd
                  @johnrudd16576
                  Q answered…..
                  Edited By John Rudd on 29/10/2017 15:38:17
                  #324283
                  mark smith 20
                    @marksmith20
                    Ok thanks
