I dont think stronger springs will affect the closing pressure. That is usually more a factor of the larger diamter of the flange on the valve disc itself. As the valve lifts off the seat, the extra area is exposed to the steam pressure coming out the valve seat, which lifts the valve well clear of the seat with a "pop" as the steam pressure is now acting on a larger area. Likewise, the steam pressure on the larger area holds valve open until steam pressure drops considerably below the set pressure of the safety valve. If you want a narrower differential between the lift pressure and the closing pressure, you may have to use a different valve, or modify your existing valve by reducing the OD Of the valve disc, but check with your boiler inspector first as it may impair safe functioning of the safety valve.
