Using a Morse taper reamer – advice please
Home › Forums › Beginners questions › Using a Morse taper reamer – advice please
  • #11406
    Simon Williams 3
      @simonwilliams3
      Using an MT2 reamer to make a socket
      #631102
      Simon Williams 3
        @simonwilliams3
        Just to pass the time between wishing the in-laws bah-humbug, I've been converting the tailstock of my S7 to be rack operated. Thus:
        Excuse the paint job (lack thereof) – it is 70 years old.
        Almost the last operation was to cut a no 2 morse taper socket in the inboard end of the new tailstock barrel. I drilled a 14 mm hole to clear out most of the material, then bored an undersize taper of very nearly the correct angle to make sure the socket would be true to the OD of the barrel. So far so good.
        I then introduced my one and only MT2 reamer into the mix. I've tried to bore MT2 sockets before using the compound slide, but found it is very difficult to get a truly linearly tapered surface.
        Here's a picture of the reamer. It's far from new, but I thought I'd give it a try.
        As you can hopefully see it's the type with a solid MT2 shank, and with serrated flutes. I'd assumed this is to make it cut more freely.
        I was surprised how quickly the gullets filled up with swarf. Am I expecting too much to use this as a metal removal tool rather than a shaping/smoothing/trimming tool? By the way the barrel material is EN32, so mild steel but with no free cutting properties worthy of the name.
        It cut a successful socket, scored near the mouth which I took to be me being clumsy with my swarf management regime, but the taper size and fit are pretty good. For the amount I shall use it I'd call it a success. Shame I cut one of the rack teeth out of position (simple typo in my list of dial settings).
        So I am planning to remake the barrel, but before I do I would appreciate some advice about how to cut an internal taper. My initial question – is this reamer a metal gross removal device – is one such, also what is the difference between this reamer and a straight flute hand held one with a square butt for use with a tap wrench? Why is one on a Morse taper shank and the other one hand-held? Do I need both?
        Should I get much nearer the final socket dimensions before using the reamer?
        Can I sharpen my serrated flute reamer by grinding the face of the flutes?
        Any thoughts?
        Thanks as ever
        Simon
        P.S. I'd rather not get involved in grinding the finished taper if I can avoid it, it will only be used for light occasional duties and I don't have the technology. By the same token I'm happy to leave it soft. The real imperative in remaking the barrel is that I mis-designed the anti-rotation slot to take the tang of a MT2 drill but my reworked barrel will have a tang slot and an ejector.
        #631104
        Ian Parkin
          @ianparkin39383
          When i make them i just drill to the small end diameter and then slowly let the reamer cut the whole taper.
          lots of cutting oil and very small increments of travel < 1mm the flutes fill rapidly and withdraw and a toothbrush to clean the flutes rinse and repeat
          #631106
          Tony Pratt 1
            @tonypratt1
            The reamer shown is a 'roughing' reamer and yes it can be sharpened as you describe, I personally would just leave the minimum amount of metal for the reamer to bring the socket to size. I will try to find my MT2 finishing reamer last used for the one and only time 40 years ago. Ah looks like there is conflicting advice already.
            Tony
            Edited By Tony Pratt 1 on 27/01/2023 15:11:51
            #631119
            ega
              @ega
              I would aim to bore this taper, with TTA if one is a available, but it can be done with the topslide set round.
              A sound taper should make the tang slot, etc unnecessary.
              An impressive project – good luck!
              Edited By ega on 27/01/2023 17:04:32
              #631129
              old mart
                @oldmart
                I have only made a male MT2 and even with the taper turning attachment on the Smart & Brown model A, the exact taper was found by trial and error using a MT2 socket as a gauge. You have to be within a second of arc or so to get a properly matching taper. To get the best female taper, I would rough out the bore as best I can and use the reamer for final perfection. I know that there are roughing and finishing reamers for Morse tapers, but have not ever bought one. The tailstock quill was not very good on the S & B and I found somebody selling them on ebay cheaply NOS and took a chance with one of the same OD. It was not for a model A, but the backlash nuts were the same. There was no extraction slot as this quill was intended for self extraction, a slot was milled to save strain on the nuts and new engraving was done tp suit the lathe. I have kept the original quill and might ream it if a reamer gets bought for another purpose.
                #631149
                Martin Kyte
                  @martinkyte99762
                  I would suggest making the morse taper socket as the first operation in over diameter material. Once you are happy with the socket mount between centres on a 2 morse mandrel and turn the outside. This will ensure the socket and the Morse taper are concentric and allow you several ‘goes’ at the socket.
                  regards Martin
                  #631153
                  David George 1
                    @davidgeorge1
                    I recently made a new tailstock quill and the only way to guarantee it to run true was to bore it with the top slide set at the correct angle, supported by the fixed steady and then finnishing it with a Morse taper ream.
                    David
                    #631155
                    Huub
                      @huub
                      I have made a lot of tapers but never for the tail stock. Maybe this is a good way to get a better and more accurate tail stock. When I mess up, I can still use the old tail stock.
                      To assure parallelism and centre height and I would put the drill in the chuck to "roughly" step bore the taper using different drill sizes and feed by using the tail stock. If you don't have the right drills, you could use a boring head. Then use the reamer to finish the job.
                      #631160
                        A serrated reamer is a roughing reamer, used mostly for production work. You need a plain finishing reamer to finish the job. I would bore the taper to within a couple of thou to ensure concentricity then finish with a finishing reamer. Try it out on a test piece first and see how it goes before doing the real job.
                        #631163
                        David Davies 8
                          @daviddavies8
                          Hi Simon
                          A bit off topic, is your rack system made to a published design, if so which one, or did you blaze your own trail? Also is the pinion housing a casting, fabricated or hewn from the solid. I have often looked at these devices with envy.
                          Cheers
                          Neil Lickfold
                            @neillickfold44316
                            Usually the serrations are offset to each other, so that when the reamer is held at a set position and the reamer has done more than 1 turn at that depth, there will be no serrations or grooves in the finished work piece. Any material taken out before the reamer goes in, is a bonus. It really needs to be all concentric as possible. You can always bore it close and then use the reamer for the last bit to get the taper into the correct MT2 range.
                            Yes those flutes will fill very fast. If you already have a through hole, use a wetvac on the end to draw away the swarf being generated, and it also will draw any coolant through as well.
                            #631165
                            jimmy b
                              @jimmyb
                              As an apprentice we used taper drill, roughing reamer and finally a finishing reamer.
                              Not seen a morse taper reamer for years.
                              Quick google turned up the below
                              If I remember correctly, they worked pretty well.
                              Jim
                              #631169
                                Posted by jimmy b on 28/01/2023 06:05:00:…
                                Jim
                                Goodness. They are not giving them away are they.
                                #631202
                                Simon Williams 3
                                  @simonwilliams3
                                  Many thanks to all the replies, we seem to have established that my reamer is a roughing one and it's no surprise that the chip clearance needs a whole lot more care. Good stuff and thank you.
                                  To answer the question about its origins from David, this was a completely off-piste design albeit a loose copy of something I've seen in a picture. I've never seen one "in the flesh" as it were.
                                  Here are the individual components:
                                  The body "casting" is two tubes bronze welded together, so the "bite" out of the side of the bigger one sets the centre distance of the pinion against the rack. Otherwise the bits are fairly simple. I chose the pinion to be 15 teeth and DP20 as this makes a full turn very nearly 60 mm travel.
                                  #631208
                                  David Davies 8
                                    @daviddavies8
                                    Simon
                                    Thanks for showing the component parts, you have made yourself a very useful bit of kit!
                                    Cheers
                                      Very nice bit of work there. And a very handy attachment.
