lathe spindle runout
Home › Forums › Beginners questions › lathe spindle runout
  • #454866
    gerry madden
      @gerrymadden53711
      Hi All,
      Here's a question I haven't seen asked before. Today I was just trueing up both sides of a faceplate and marking it so I can mount it in the same rotational orientation next time I fit it. But would it not be a little more sensible to skim the spindle flange face before trueing the faceplate ?
      The lathe came with a certificate indicating its spindle flange face runout. (I cant recall the figure now but it was probably in the order of 5um or so.) This figure will be an accumulation of several things: basic machining errors on the spindle, runouts in the bearings and runouts from assembly error. These are maintained unless the spindle is dismantled and rebuilt slightly differently. So providing I don't dismantle the spindle, by skimming the spindle's face I can remove all of these errors and reduce the measurable face runout to nominally zero. This can only improve the runout and wobble on any subsequently fitted part such as a chuck, and remove the need to orientate the fitments, cant it ? And if so, why wouldn't a manufacturer do it ?
      Perhaps I'm missing something ?
      Gerry.
      #10098
      gerry madden
        @gerrymadden53711
        #454867
          5 micro metres? Could you ‘skim’ it any better?
          If it is a chinese certificate, it may not be worth the paper it is written on.
          Edited By not done it yet on 01/03/2020 12:42:56
          #454868
            deleted.
            Edited By not done it yet on 01/03/2020 12:41:57
            #454869
            gerry madden
              @gerrymadden53711
              NDIY – it isn't Chinese, but if it were, and 'not worth the paper', all the more reason to skim ?
              #454870
                It may well have had some sort of hardening treatment so watch that any skim you take does not push the tool off and possibly give you a worse finish than you started with. Also and spigot or short taper that locates the backplates may also need to be trued to the skimmed flange making it smaller which would mean all new backplates, etc.
                #454872
                Anonymous
                  Two issues; first how do you know that a skim will produce a "zero" result? And second cost, it would be time consuming, and hence expensive, to do.
                  As Jason says the spindle should be hardened, which makes it more difficult to turn. Will the cross slide travel in a straight line perpendicular to the spindle axis to considerably better than 5um? Probably not, and the cross slide should turn from parallel to slightly concave. So it may not even be aligned.
                  Manufacturers aim to make parts to fit together to achieve an acceptable level of accuracy without the need for fitting on the job. Didn't the original Myford do a lot of fitting, with it's attendent costs? I wonder what happened to them?
                  Having said all that I have skimmed the nose of my Bridgeport spindle:
                  But it was out by a lot more than 5um. Of course in normal use the run out on the nose doesn't matter. But I make extensive use of the Tormach TTS tool system which relies upon the spindle nose to provide consistent positioning for tool length calculations. If the spindle nose isn't true then the tool wobbles.
                  #454874
                  HOWARDT
                    @howardt
                    Each part in the tool mount train will be manufactured to a tolerance. While the tolerances are tight there will always be some degree of geometric variation introduced at the tool point or workpiece, even bar material is not truely round or square. Achieving near zero is done by tuning the final mount, so both the tool and the workpiece are true to each other. There has been discussions on this forum last year on machine tolerance.
                    #454880
                      Gerry,
                      I believe the test you mention is what Dr Schlesinger describes as:
                      Work spindle for axial slip, measured at 2 points, displaced by 180°
                      … if so, five microns would be acceptable for a Toolroom grade lathe.
                      You may want [or even need] better ; but I think that would likely require that the face be ground, or lapped, in situ.
                      MichaelG
                      #454896
                      old mart
                        @oldmart
                        It would be worth actually checking the spindle runout, but if it is 5 microns, then leave it well alone. I was lucky to get hold of a 9" faceplate cheap on ebay which I was 90% sure was a genuine Smart & Brown one. It was, and when fitted, it ran 0.0005" tir at the periphery which saved me the trouble of skimming it.
                        #454931
                        gerry madden
                          @gerrymadden53711
                          Thanks all for your comments. I have to admit to having a bit of a thing about precision so I would have probably given it a go anyway . I did however try to measure the actual runout first but that wasn't that particularly successful due to pretty poor surface finish on the flange. But overall it looked to be about 5um including the chatter. So I proceeded to make a very light cut starting on the bolt pcd then moving in and out to cover the whole flange. Considering the lightness of the cut I expected to see areas appearing that were not cleaned up. But there weren't any, which suggested that either the depth of my 'fine' cut was of the same order as the runout (or far bigger of course!). Anyway here was the result:-
                          The intermittent cut from the bolt holes wasn't detectable at all and I was careful not to touch the spigot diameter. The 0.2 rad on the tip appeared to match the existing one quite well too. I then tried to remeasure the flange runout like this:-
                          …and guess what…. it wasn't much better than it was before despite the significantly improved surface finish. What I could see though was that the runout was absolutely not synchronised with the rotation of the spindle. So there are literally other forces at play here – possibly variations in drive belts or drive train making the spindle do strange things.
                          Well no harm done and a few things leaned. A good way to finish a wet Sunday.
                          Gerry.
                          #454955
                            Posted by gerry madden on 01/03/2020 20:25:28:
                            .. it wasn't much better than it was before despite the significantly improved surface finish. What I could see though was that the runout was absolutely not synchronised with the rotation of the spindle. So there are literally other forces at play here – possibly variations in drive belts or drive train making the spindle do strange things.
                            Gerry.
                            One of the reasons 1um dial gauges and not guns should require licenses. You can spend your whole life chasing your tail with them in the home workshop.
                            You probably should have adjusted your headstock bearings first. If they are tapered roller etc and the end float/preload is not set right, your spindle will be all over the place.
                            Also you should run the lathe for half an hour to warm up the spindle and bearings to operating temps before taking a reading.
                            An elephant foot probe on the dial gauge would help it being influenced quite so much by surface finish.
                            I reckon I would use a HSS tool bit for such fine cuts too. The carbide can skate a bit on light cuts, which might be giving you your 5um variation. Possibly.
                            But if you've got it within 5um and Mr Schlessinger is happy with that, best leave it well alone and call it job well done.
                            #454980
                            Martin Kyte
                              @martinkyte99762
                              If I were you I would leave the spindle well alone and skim your face plate as you suggest. If you find you really must have a faceplate as true as you can get it for a special job you can always reskim as neccessary before you mount your work. the only time I have every felt the need to do this was when monting 2 faceplates face to face to give a female myford nose mounting to turn a spindle for a dividing head.
                              regards Martin
                              #454986
                                Posted by gerry madden on 01/03/2020 12:53:35:
                                Not for ~5 microns it ain’t – and that is likely the maximum. Not for me, anyway – I don’t even have the kit to measure much better than that, let alone try to do much better by adjustment of an ‘unknown’ quantity.
                                #454992
                                gerry madden
                                  @gerrymadden53711
                                  Hi Hopper, thanks for your comment.
                                  The spindle bearings are fine. They are taper rollers and positively preloaded. With the spindle stationary, using the micron DI its easy to see the elastic deflection as one pushes and pulls the spindle axially. Rough estimate was that the deflections are about 2um/Kgf in both directions and it returns exactly to the centre position when unloaded which confirms no clearance in the assembly.
                                  That's deflection figure is probably a bit too compliant for TRs so I suspect that a good part of that elastic deflection is deflection in the aluminium structure walls in which they are mounted.
                                  Absolutely agree on the elephants foot. I didn't think of that ! Will give it a try later.
                                  Gerry
                                  #455003
                                    Interesting. Let us know how it goes.
                                    #455023
                                    Martin Connelly
                                      @martinconnelly55370
                                      Quote attributed to Voltaire. Quote
                                      Martin C
                                      #455025
                                        Assuming too that tests are done with spindle rotated by hand, no belts or power on the spindle.
                                        And what kind of lathe is that? I had thought it was something larger and heavier for some reason, but looking at your posted pics, seems unusual with the round bars for bed ways. Is it a little Unimat or some such? In which case, not sure how relevant industrial Schlessinger limits etc might be. No wonder you can measure some movement in the spindle axially even with bearings nipped up. I see what you mean about possible flex in the alloy bearing housing now.
                                        #455029
                                          It's a Wabeco
                                          You mention that the runout is not even, has the lathe been sitting for a long time and the belt taken a "set" which could give that sort of reading and again all the more reason to run it for a good half hour or so before taking readings more so if your workshop is not that warm.
                                          #455031
                                          mgnbuk
                                            @mgnbuk
                                            I have seen this once before on a Timken crossed roller bearing, and it was the bearing that was the cause.
                                            Application was a vertical borer table bearing and, when checked, the axial runout was within limits (0.04mm at 1500mm diameter). The machine had been rebuilt & the table bearing had been refurbished by a bearing specialist – inner & outer races reground & new rollers made – as a replacement bearing was on 2 years delivery.
                                            The machine had been accepted after machining trials on the customer's own components (quite thin disc hub forgings in titanium & nimonics) & I was having a leisurely breakfast before flying home when there was a call from the customer with a surface finish problem on a much higher job they had taken in & run overnight. After much checking I found that while the axial runout at the table outer edge was always within limits, the actual reading at each point varied if multiple turns were made – easily seen as I marked the DTI reading in marker pen at each measuring point. Turned out that the bearing refurb company had not made the replacement rollers accurately enough (discussions with Timken revealed they used rollers matched to within 1 micron) and, as the rollers move around when the bearing rotates, the individual rollers under the measuring points were different each time. Not enough to show a surface finish problem on low parts, but visible on the tall part. The bearing was swapped out for one from another machine being rebuilt & this one gave consistent results over multiple rotations – surface finish on the component was then OK. The "dodgy" bearing got a set of more consistent rollers & that also performed OK when mounted.
                                            Do you know what the spindle bearings are that are fitted (part number & precision class) ? Axial runout is one of the variables that is tightened up with higher precision bearings & the allowed values vary with bore diameter.
                                            Nigel B.
                                            #455034
                                            Martin Kyte
                                              @martinkyte99762
                                              I've never really been convinced that anything like all of the run out in many cases is actually the spindle rather than the mounting point of the dial gauge wandering around, particularly when the gauge is mounted in the toolpost.
                                              Removing belts should help as has been mentioned above, but a gauge mounted on the headstock casting would be more convincing. Resting your arm on the tailstock of most Myfords will shift the toolpost out of line by a few 10's of a thou.
                                              regards Martin
                                              #455042
                                              gerry madden
                                                @gerrymadden53711
                                                Martin C – ha ha, its true. I spend my day being pragmatic and cant stand others who delve in to things that really don't matter. At weekends I like to chase perfection for fun even when its stupid, which is most of the time
                                                Nigel B – you are absolutely right. NRR or non repetitive runout is often caused by rolling element size differences or shape errors. Its non repetitive because their own rotational speed relative to the raceway surfaces, and their speed around the bearing is not synchronised with the ring rotations. so they can produce almost random-like motion in the rotating shafts. NRR used to be a big challenge on computer hard-drive spindle brgs where precision was all, but I have never heard of it being and issue in big brgs before. Good to hear about your case.
                                                I have just rechecked my spindle face axial runout with the 'Hoppers Elephants foot' and it has really cleaned things up. Here's the set up:-
                                                And here's the results:-
                                                The spindle was turned by hand and the DI was pulled back to go over the bolt holes. I was careful not to touch the slides, (which I forgot to lock down anyway!)
                                                There is an obvious underlying runout but there is also clearly a non-repeating element to the figures of around half the magnitude of the fundamental. As was suggested by Michael G, with a very fine and slow grind, one could remove another micron or two from the repetitive runout but there is no simple way of removing the non-repititve part without improving almost every other part of the machine. Its difficult to say precisely what's causing the NRR but the main contributors have to be the drive train and bearings
                                                When I got the machine the belts (6 ribbed poly-vee) had a pronounced sets moulded in and these caused an audible bump every time they hit one of the pulleys. So I sliced the belts into two 3-ribbed pieces and staggered the moulding inconsistencies. This really reduced the noise and although I didnt think of it at the time must have helped the true running of the spindle. Perhaps there are some better belts available which wont cost an arm and a leg. Of course runouts in the pulleys themselves will cause load variation too.
                                                As for the bearings, these are just standard precision eastern European taper roller type. There is no point in using a better quality product as I already know the housings are quite poorly machined. It makes no sense to put a good bearing in a rubbish housing because the geometric errors just get carried through to the raceways. I have actually wondered about replacing the TRs will ball bearings as a simple "upgrade". I know some people will frown at this say that its going the wrong way, but the advantage here would be that because the balls are more compliant they will absorb some of the geometric irregularities instead of passing them straight in to the spindle.
                                                I'm certainly not going to be short of things to do when retirement arrives, that's for sure ! But for now I think I've just about done as much as I can with the spindle on this bag of old nails, short of speeding real money.
                                                Gerry
                                                #455045
                                                old mart
                                                  @oldmart
                                                  4 microns tir is an excellent result, when a chuck is fitted, the results will multiply 10 to 20 fold, so chasing that tiny amount already present is a total waste of time.
                                                  #455322
                                                  Nigel McBurney 1
                                                    @nigelmcburney1
                                                    I was once involved in hard drive manufacture,the tolerances were out of this world,the spindle bearings were ball type and had relatively large internal clearance,the two bearings were axially spring loaded,I was mainly involved in procuring parts for production and only heard that there had been problems with random runouts in the early days,The problem with production quantities was the amount of grease in each bearing,which was critical to the life of the bearing. Regarding bearings on machine tools,horizontal mills tended to use taper roller on heavily loaded horizontal bearings and on the heavy vertical heads,whereas the higher speed light vertical mills tend to use ball bearings.I was involved with a very large American vertical CNC mill boring ali castings for hard drives,after some problems it was decided to replace the spindle bearings,these were a pair of opposed precision ball races ( at precision price) about 120 mm dia ,and being nosey I asked why balls not taper roller and the factory man said the ball bearings were in their experience,better than taper rollers.and there was no comment on why the bearings had only lasted 3 months of round the clock running.
                                                    #455332
                                                    mgnbuk
                                                      @mgnbuk
                                                      TRBs don't like running fast with high preloads, as they generate a lot of heat. Timken used to make a version called the HydraRib that could vary the preload with hydraulic pressure – I had seen them in the Timken catalogue, but only came across one on a DeVleig jig borer. There was a two pressure hydraulic circuit that put on a high preload at low revs where high stiffness was required for heavier milling then changed to a low preload at high speeds – the change was automatic via a solenoid valve that switched over at a particular gear range.
                                                      Probably a "greased for life" installation & in that application "life" was 3 months. Had something similar with a Marwin gantry type router that used motor spindles (a heavy duty electric motor with the shaft being an ISO40 spindle). These ran right at the top end of the bearings rated speed & typically lasted 9-10 months between bearing changes. The Kluber grease had to be accurately weighed & carefully applied, then "run in" over a couple of days by carefully increasing the speed in small steps while monitoring the internal temperature of the tool taper.
                                                      I got to visit the Bridgeport works in Leicester on a DTI "Inside UK Enterprise" visit – they built up their spindle cartridges in a clean room & had automatic "running in" rigs to get the spindles correctly run in before they were fitted to machines.
                                                      Nigel B.
