Wifi range extender
Wifi range extender
Home › Forums › Help and Assistance! (Offered or Wanted) › Wifi range extender
  • #608226
    duncan webster 1
      @duncanwebster1
      I my box of things which will come in useful I've found a Sitecom N300 range extender. I've probably got the wall wart as well, but the unit doesn't tell me what voltage it should be. If anyone out there has one of these and would have a look at the wall wart I'd be grateful
      #34060
      duncan webster 1
        @duncanwebster1
        #608233
        Chris Crew
          @chriscrew66644
          I have no idea about the devices you are talking about and never heard of the term 'wall wart' either, so please make allowances for my ignorance. It's just that I bought a wi-fi extender off Ebay for about a tenner so I could get Spotify through the laptop down in the workshop on an old hi-fi I have down there. It consists of nothing more than a 13-amp plug sized box that goes straight into a 13amp socket. I just selected it on the wi-fi connections list, entered the router's password and away we went. Worked perfectly first time and can be just switched off at the socket when I return to the house. Worth a tenner, including delivery.
          #608236
          Clive Foster
            @clivefoster55965
            Duncan
            Sitecom used the N300 designation for a host of different products, range extenders, routers and other wi-fi related stuff. Which doesn't help when you are trying to nail down data.
            However if its the WLX-2001 the wall wart included is saId to be 5 volts, 1 amp rating.
            Manual here :- **LINK**
            http://attachments.content4us.com/datasheets/FULL_MANUAL_CMPSC-WLX2001_ENG.PDF
            Odds are that everything in the range using the same basic box will also be 5 volts as there is generally lots of engineering commonality across one makers range.
            Always worth doing a Google for the specific manual. Seems that manuals for pretty much anything consumer electrical / electronic and reasonably modern can be found.
            #608237
            John Haine
              @johnhaine32865
              …not to mention lots of slightly older VLSI devices being designed for a 5V supply…
              #608238
              peak4
                @peak4
                It looks like it might be 12v 1a
                It seems that Sitecom use the N300 name on several products, but the extender seems to be a WL-330
                 https://www.sitecom.com/en/search/229?searchInput=wl-330
                See P36 of this manual, but just make sure it's the right item
                https://www.manua.ls/sitecom/wl-330/manual?p=36
                Bill
                Edited By peak4 on 02/08/2022 22:07:52
                Edited By peak4 on 02/08/2022 22:08:33
                #608239
                Grindstone Cowboy
                  @grindstonecowboy
                  Just to clarify for Chris, the part you refer to as "a 13-amp plug sized box that goes straight into a 13amp socket" is what is nowadays commonly called a "wall wart" – basically a power supply, changing the 240 volt AC mains to a lower, usually DC, voltage.
                  Rob
                  #608240
                  Chris Crew
                    @chriscrew66644
                    Rob, Thank you for the information you have added to my education and I appreciate it. I had never heard of the term before now, may be I really should get out more? LOL.
                    #608242
                    lee webster
                      @leewebster72680
                      Wall wart is a new one on me!
                      #608244
                      duncan webster 1
                        @duncanwebster1
                        Further examination of the name plate with a magnifying glass identifies it as WL330. I'll follow Peak 4's link tomorrow, thanks
                        Wall wart is I think an Americanism, but it is so descriptive I think it deserves to be adopted into proper English
                        #608257
                        Circlip
                          @circlip
                          The type Chris is describing seems to be the TP Link which is a self contained wall plug NOT a wart.
                          Regards Ian
                          #608280
                          Grindstone Cowboy
                            @grindstonecowboy
                            Ian – very good point, I hadn't read Chris's post properly blush
                            Rob
                            #608287
                            AdrianR
                              @adrianr18614
                              If this is the one you have https://manuall.co.uk/sitecom-wl-330-range-extender/ then at the end of the manual it says 12V 1A
                              #608324
                              norm norton
                                @normnorton75434
                                I was aware that 'wall warts' was an American term and something to do with power supplies sitting in wall plugs, but are the letters W,A,R and T an acronym? or does it just mean a ugly lump sticking on the wall? If the latter then the term is best left on the other side of the Atlantic Ocean.
                                #608340
                                Anonymous
                                  Not an acronym as far as I know. Happy to keep "wall-wart" on this side of the Atlantic. Sure beats saying "power supply thingy with prongs that sits in an electrical outlet"
                                  wink
                                  #608345
                                  John Olsen
                                    @johnolsen79199
                                    I've seen them called plug packs in the past, not sure how widely used that is now.
