What size injector
What size injector
Home › Forums › Beginners questions › What size injector
  • #110865
    nigel jones 5
      @nigeljones5
      Since my waterpump nearly tore my loco apart im switcging to injector. I nwant to buy one – but dont know what size. Loco is smilar dims to pansy, max 100psi. Can you advise what size, where to buy on net and any issues to beware of please?
      nigel
      #6560
      nigel jones 5
        @nigeljones5
        #110894
        61962
          @61962
          Take a look at this
          http://www.model-engineer.co.uk/forums/postings.asp?th=78871
          Should give you some guidance
          Eddie
          Edited By 61962 on 03/02/2013 23:06:11
          #111061
          nigel jones 5
            @nigeljones5
            Thanks – only thing it says is that a no.2 will be adequate on even a big 5" gauge loco – but its tiny! Ive opted for a no.4, is this a mistake?
            #111073
            61962
              @61962
              Nigel,
              Two 11 ounce injectors will be fine. You'll only need one most of the time, the second one for when you let things get out of hand. Your No 4, 25ounce, will fill the boiler too fast, kill your steam and it'll be on and off like a ………. One problem you will have though is that being a tank engine the water will get hot and the injectors won't like that. You will need a water tank on your driving car or you could build a wagon to use as a water and coal carrier.
              My Adams tank runs fine on two 11 ounce injectors. It usually does one lap of our track with the injector on and one with it off. It draws it's water from the bunker tank, but I can top up from my driving car when running on ground level railway. When its got a good load behind it (say approaching half a ton) one injector is on for long periods, but I rarely have to start the second one.
              Good luck
              Eddie
              #111138
              nigel jones 5
                @nigeljones5
                Thanks – going to see if I can get the hang of one 11oz injector working for starters. I hear a lot of scare stories about water and steam flow restrictions, so is it worth going bigger on these feed pipe bores?
                #111186
                61962
                  @61962
                  Nigel,
                  Use 5/32" od for steam, 3/16 for water and feed. Smooth bends – no elbows on the feed side in particular. A plug cock for the water valve rather than a screw down valve (too restricting) and make sure the water feed has no air leaks. And you need a large area fine filter at the water draw off point.
                  Eddie
