What size facemill?
What size facemill?
Home › Forums › General Questions › What size facemill?
  • #203665
    Chris Denton
      @chrisdenton53037
      Looking to buy a cheapest facemill with carbide inserts.
      I've never used one before, so am wondering what size I can use.
      The milling machine is an Aciera F3 with a 1hp spindle motor and 3hp feed motor.
      Thanks,
      #24101
      Chris Denton
        @chrisdenton53037
        #203673
        Les Jones 1
          @lesjones1
          Hi Chris,
          3 HP seems awfully large for a feed motor.
          Les.
          #203678
          Ian S C
            @iansc
            Your spindle motor is about the same power as my Rexon mill, I use a 50 mm dia face mill with three 16 mm triangular inserts. The one originally supplied with my machine(I didn't get one) were 2 1/2" dia with six cutters, I think they may have been HSS.
            Maybe the feed motor is .3HP
            Ian S C
            #203682
            Thor 🇳🇴
              @thor
              Hi Chris,
              I am using a 63mm facemill with four inserts on my my milling machine (slightly larger than the Warco WM16). I don't take heavy cuts, but the facemill works well even on my lightweight machine. You shouldn't have any problems using a 63mm facemill on yours. I also have a 30mm with two inserts.
              Thor
              #203684
              Ajohnw
                @ajohnw51620
                If you want to go as big as possible you might be able to get a feel for size via a fly cutter. Your question can't be answered really as size, depth of cut, speed and feed rate all determine the HP needed. More cutting points helps a bit with feed rates.
                Personally if I had your machine I would probably be more interested in horizontal milling if I had the full horizontal attachment that supports a bar for cutters at both ends. Flat surfaces rather than dished due to head alignment errors.
                You might find some demo's that use the machine on youtube.
                Edited By John W1 on 09/09/2015 13:32:42
                #204010
                Chris Denton
                  @chrisdenton53037
                  Thanks.
                  The feed is 3HP, the same motor is used for the horizontal milling. I just want something I can put into the vertical head to save stopping things around.
                  #204018
                  NJH
                    @njh
                    Chris
                    Aciera F3 !!! – lucky you. A superb and flexible bit of kit. I ' ve seen one but, as it was in the boss' partitioned off section of the workshop , I never got to use it!
                    Norman
                    #204023
                    Chris Denton
                      @chrisdenton53037
                      I've heard of that before, the boss at a machine shop keeping one of these for his own use!
                      #204029
                      Bazyle
                        @bazyle
                        It may be a case of what mounting you have and what you can find to fit it directly to maintain rigidity. Also the range of feed speeds may be limited as is often the case with horizontals used for feed. One way of looking at it is that it is 2/3 the size of a Bridgeport.
                        #204039
                        Ajohnw
                          @ajohnw51620
                          They use iso 30 or w20 fittings. Min feed 12mm per min – couldn't help looking. That may be with the motor in low speed mode.
                          Personally I would rather find the right Thiel with it's bits an pieces. No space for one though. It's really unusual for me rate German machinery highly but that one can be really interesting but a pain to set up.
                          Chris Denton
                            @chrisdenton53037
                            That's it. Mine has W20 on both spindles. I have a W20 – MT2 adaptor though.
                            Minimum powerfeed speed in low power is 12mm/min as you say, maximum in high power is 252mm/min. What would I use with a face mill, the slowest?
                            #204083
                            Ajohnw
                              @ajohnw51620
                              No point asking me I have only used 10in dia ones on rather large machines and have hand fed. Never at home. I have been toying with getting one for my dore westbury but am not keen on the price of re tipping the ones that take a lot of inserts. I'm inclined to try one around 3in dia but wouldn't expect to be able to take much of a cut with it. That takes 2 morse but also has a myford spindle nose so I would have to make something to fit it on that.
                              I'm pretty sure you will find a demo of face cutters using your machine on youtube and can get and idea of size from that. I'd guess w20 arbours are bound to be available. It's a schaublin design.
                              Bazyle
                                @bazyle
                                The feed speed depends on both the diameter and number of teeth (inserts).
                                First the spindle speed is calculated using the cutter diameter to give the right surface speed of the tooth through the cut for the material. That gives you the number of cuts per second.
                                Then you decide the depth of cut (sideways) per tooth and hence the rate of advance needed to meet this.
