What is this designed to do
Home Forums General Questions What is this designed to do
Viewing 21 posts - 1 through 21 (of 21 total)
  • #238045
    hth
      @hth
      Hi
      I recently found this device, it has a Mercer .0005" dial indicator on it . There is a flat machined onto the bar directly beneath the dial probe .
      It has the following crudely stamped onto the tag
      THIS INDICATOR IS FITTED WITH A DIAMOND BUTTON PLEASE LOWER ONTO STORE DO NOT ALLOW TO DROP FREELY
      Edited By hth on 09/05/2016 12:08:32
      Edited By hth on 09/05/2016 12:10:42
      #24534
      hth
        @hth
        #238047
        John McNamara
          @johnmcnamara74883
          Hmm…
          The object being measured has an end otherwise the ejector would not work
          I think it is for checking wigwams for a gooses bridle.
          Or maybe a thingamajiggera
          Cheers
          Edit
          The Mercer Indicator is very nice.
          Edited By John McNamara on 09/05/2016 12:21:35
          #238053
          RICHARD GREEN 2
            @richardgreen2
            Looks like a Mk1 square ended Gangle pin adjuster……………………
            The Mk2 was the Metric version…………………..
            It had a diamond point because the Gangle pins are hardened……………………….but only on Wednesdays.
            #238057
            roy entwistle
              @royentwistle24699
              Hardness tester ?
              #238062
              Hopper
                @hopper
                I guess it's for gauging/checking the "STORE" onto which the diamond point should be lowered and not dropped.
                A relic from the days when quality control was done at the factory, not by the purchaser.
                #238067
                  Posted by Hopper on 09/05/2016 14:18:49:
                  I guess it's for gauging/checking the "STORE" …
                  Definition of "Aircraft Store" to maybe narrow things down just a little:
                  charadam
                    @charadam
                    It's a pedant attractor.
                    #238073
                    RICHARD GREEN 2
                      @richardgreen2
                      It dosen't look like a tractor………………..
                      #238077
                      KWIL
                        @kwil
                        In this case "store" is the resting location for the diamond tip when not in use, otherwise it would be "the store" It is a comparator of some sort.
                        #238078
                          Posted by charadam on 09/05/2016 15:38:17:
                          smiley
                          #238084
                          Ed Duffner
                            @edduffner79357
                            Does the label give any clues?
                            I'd guess it could be a fixture to check the height or swing of various objects mounted on a hollow shaft – camshaft of some type maybe? …not necessarily an engine camshaft.
                            Ed.
                            #238089
                              Posted by Ed Duffner on 09/05/2016 17:54:25:
                              Assuming that label = tag = affixed plate :
                                Posted by KWIL on 09/05/2016 16:16:50:
                                Given that neither interpretation constitutes an English sentence … How do you know that with such apparent confidence ?
                                I.M. OUTAHERE
                                  @i-m-outahere
                                  Looks like something to check wall thickness on a tube or pipe , maybe ammunition ?
                                  #238135
                                  Nicholas Farr
                                    @nicholasfarr14254
                                    Hi, assuming that the shaft with the black disc on, rotates and travels from L/R and or R/L, could it be for checking any oval-ness of tubes? I was also thinking some type of ammunition perhaps.
                                    Regards Nick.
                                    #238136
                                    Nicholas Farr
                                      @nicholasfarr14254
                                      Edited By Nicholas Farr on 10/05/2016 06:49:44
                                      #238138
                                      Hopper
                                        @hopper
                                        Oooh. So nothing to do with model engineering then. smiley
                                        #238143
                                        Hopper
                                          @hopper
                                          Posted by Michael Gilligan on 09/05/2016 14:42:03:
                                          Including "nuclear bombs"? Yikes.
                                          Could it be for checking deformation of used brass cartridges from aircraft machine guns prior to reloading then?
                                          Measuring the diameter of the the main horizontal round bar might give a clue as to calibre?
                                          Could be along the lines of a modern day "neck checker" used by home reloaders for small arms rounds?
                                          Diamond tip on the dial gauge on the mystery machine suggests it is made for bulk production useage, without wear. Maybe wartime reloading? Any way to date the Mercer gauge to see if it fits wartime era etc?
                                          What else would you use a diamond point for? Mass production environment or measuring very abrasive surfaces is all I can think of.
                                          Edited By Hopper on 10/05/2016 07:53:08
                                          #238150
                                          Martin Paffett
                                            @martinpaffett76960
                                            There are a couple of clues that suggest to me that it is not military (qualification – 37 years in RAF):
                                            The label lacks any stores reference number/stock number. The DTI would have calibration information. It might have a "crow's foot", but not necessarilly.
                                            The use of the word "PLEASE" – this would never happen in a military instruction!
                                            Aircraft machine gun/canon spent cases are not reused.
                                            The gap between the button and the anvil is clearly too large for measuring thin-walled ammo cases.
                                            The anvil has a flat, which would negate measuring material thickness of a parallel tube.
                                            Just random thoughts – doesn't help much – sorry.
                                            MP
                                            #238167
                                            Hopper
                                              @hopper
                                              LOLz, we'll take that as conclusive then.
                                              It seems we are back to "pedant attractor".
