What are these drills called?
Home › Forums › General Questions › What are these drills called?
Viewing 25 posts - 1 through 25 (of 28 total)
  • #177817
    Chris Denton
      @chrisdenton53037
      I am looking to buy another few of these drill bits, they are self centering and have a very steep helix.
      Any ideas what they are called?
      #23690
      Chris Denton
        @chrisdenton53037
        #177818
        Chris Denton
          @chrisdenton53037
          Edited By Chris Denton on 30/01/2015 13:33:42
          Edited By Chris Denton on 30/01/2015 13:34:36
          #177819
          Martin Kyte
            @martinkyte99762
            Spotting Drills?
            Martin
            #177820
            andrew winks
              @andrewwinks64215
              Who is selling and price?
              #177836
              Roger Provins 2
                @rogerprovins2
                I've always known them as slow spiral drills.
                Available here (and many other places I'm sure).
                http://www.drill-service.co.uk/Tools.asp?Tool=020240000000
                #177844
                  I'd say a slow spiral as well, definately not a spotting drill.
                  #177849
                    The angle on the end is greater than 118 degrees, rather than less, looks like a stub drill meant for sheet metal to me.
                      Posted by JasonB on 30/01/2015 16:09:49:
                      How strange … I would have described something with a large "pitch" as having a fast spiral, not a slow one.
                      Might be wrong though … must check.
                      Anonymous
                        Definitely slow spiral; intended for hard materials, as the cutting edges are stronger than standard helix drills, or for materials that tend to 'snatch', like brass. Presumably if it is self-centring it is 4-facet ground, although that is not clear from the picture.
                        #177853
                          Here you go Michael, slow and fast
                          #177854
                          Harry Wilkes
                            @harrywilkes58467
                            Talking of drills I was looking through the box of stuff that came with my lathe for a 12mm drill came across a Dormer drill still in it's red sleeve it was a 21/32 don't know why but opened it up and was surprised to find it contained a 3 flute drill never seen one before what would be it use /
                            H
                            #177857
                              Posted by JasonB on 30/01/2015 16:53:05:
                              Thanks Jason
                              Happily corrected
                              mick
                                @mick65121
                                Sounds like a core drill that's designed to follow a pilot hole and produce a nice true and size hole without the web snatching that would probably occur with a twin flute.
                                #177864
                                  They aren't even slow spiral, they are slow helix. A spiral is only 2-dimensional
                                  Brian Rice 1
                                    @brianrice1
                                    I remember buy some years ago for drilling brass.
                                    #177868
                                    Roger Provins 2
                                      @rogerprovins2
                                      Posted by Neil Wyatt on 30/01/2015 18:17:02:
                                      For the pendantic maybe (same as a helix staircase?) but for everyone else they are spiral
                                      Roger
                                      #177869
                                      Anonymous
                                        It used to be possible to buy straight flute jobbers drills specifically for brass.
                                        Never mind pedantry, if we're being mathematically correct a helix is simply a special case of a three dimensional spiral. There's nothing that says a spiral has to be two dimensional, or indeed limited to Euclidian geometry.
                                        #177870
                                        Muzzer
                                          @muzzer
                                          Good for brass or possibly tough materials as Andrew says. Saves having to square off the leading edge of a normal steel cutting drill with a slip stone, which many people consider a clever trick.
                                          I also have some for drilling aluminium which have a "faster" helix than normal. They came in a mixed bag of drills from Tracy Tools back in the 70s. I was disappointed at the time, as I thought I'd paid for a "set" of drills. However, they are great when used for their intended purpose and they refunded my dosh when I complained which worked for me, being a Scottish-blooded Yorkshireman.
                                          Murray
                                          #177924
                                            I suppose that if you stretch a point a helix is a spiral on the surface of a cylinder.
                                            Isn't there a version of a spiral that links the two 'poles' of a sphere?
                                            Yes
                                            Russell Eberhardt
                                              @russelleberhardt48058
                                              Interesting link Neil but be careful, someone will be along soon complaining that the OP only asked what that drill is calledsmiley
                                              Russell
                                              #177935
                                              Rufus Roughcut
                                                @rufusroughcut
                                                Hi Gents
                                                Surely a two dimentional spiral / helix is merely a zig-zag line, unless of course its dimentions where away from you then it could apear to be a stright line.
                                                sorry to pedantic
                                                #177952
                                                Chris Denton
                                                  @chrisdenton53037
                                                  Thanks for the link Roger that was exactly what I was looking for.
                                                  #177970
                                                  Bodgit Fixit and Run
                                                    @bodgitfixitandrun
                                                    A Spiral starts at a centre point and flows away from said point in a circular path with a progressively increasing radius on a flat plane so is two dimentional.
                                                    A helix starts at a point on a circumference and rotates around the circumference at the same radius, if it is a parallel helix, moving forward with a given pitch eg. a screw thread. It can also move out with a progressive radius as on a cone. With the cone, when viewed from the tip, you can see a spiral in two dimentions but you won't see the helix as the always have effectively some form of forward motion.
                                                    Also, just in case someone notes, a helix can also have a variable pitch but I don't know why you would want one.
                                                    Spiral staircases are so called because of how they look from the plan view where the tread appears to rotate out around a given centre point ie the column. which geometrically is actually a cylinder with a very very deep thread with an equally deep pitch wrapped around it therefore a helix.
                                                    Edited By Bodgit Fixit and Run on 31/01/2015 15:48:43
                                                    #177973
                                                    Anonymous
                                                      Posted by Bodgit Fixit and Run on 31/01/2015 15:46:57:
                                                      See here for some examples:
