What am i going to make with this scrap
Home › Forums › The Tea Room › What am i going to make with this scrap
  • #463617
    Steviegtr
      @steviegtr
      Well my son has put new compliance bushes on his Golf GTI front suspension & was throwing away 2 of these. I said no I will have them. Solid Alloy 1st thing I saw was taking the old bushes out & milling something a bit different. Tig welding an alloy bottom on one end. A little handle on the piece sticking out. Then using it for cutting fluid with a little brush. Polish it all up.
      Any other idea's. Too good to throw away.
      Steve.
      #35848
      Steviegtr
        @steviegtr
        #463624
        Speedy Builder5
          @speedybuilder5
          More scrap ?
          #463625
          not done it yet
            @notdoneityet
            Melt them and cast something useful – just round or flat bar would be a start.
            #463640
            Chris Evans 6
              @chrisevans6
              For me messing with those would be misdirected energy.
              #463648
              Perko7
                @perko7
                Cup-holder to bolt to the side of the lathe or milling machine??
                #463650
                  Good idea, time for Steve to stop improving his tools and put them to work! Converting an odd shape into something useful is always satisfying, and holding and cutting that odd shape will be a worthwhile exercise.
                  However, rather than going free-form as artists sometimes do with an angle grinder, a better engineering exercise is work to a dimensioned plan. Looking good isn't the main engineering challenge, rather the hard part is first making objects to a particular pre-planned size and finish. (Any fool can polish an old penny, much harder to make a replica.)
                  I'd suggest some other targets just to make it interesting. Everything in the new shape to be made from the Golf part, and at least two parts must be screwed together.
                  Go for it!
                  Vic
                    @vic
                    Given the published poor reliability of German cars I’d have let it go in the bin … smiley
                    #463656
                    BOB BLACKSHAW 1
                      @bobblackshaw1
                      Reading this post on scrap and what can be made from that, I made two of these the other week. A flower pot ,a kneeling mat, a bit of stainless from a waste bin, a bit of old sofit board, roasting rack for the feet, and a beer ca a bit of rod for the counterbalance . They make good wind garden ornaments, it would be good for some others making one as a rest from the shed as they can be made outside in this nice weather.
                      Edited By BOB BLACKSHAW on 10/04/2020 10:34:36
                      #463691
                      AdrianR
                        @adrianr18614
                        You could make a pair of coffee cups to match This Old Tony's Coffee Pot
                        #463695
                        magpie
                          @magpie
                          Apart from the electrics, I made this entirely from scrap.The finished clock.
                          #463696
                          Alfie Peacock
                            @alfiepeacock58331
                            That's good Bob, I brought one like that made out of a coconut, I think I'll have a go at making one.
                            Alfie
                            #463702
                            Bazyle
                              @bazyle
                              Posted by Vic on 10/04/2020 10:18:42:
                              you mean if he follows his original intention of a cutting fluid container he will find himself using more than he expected? wink
                              #463709
                              Steviegtr
                                @steviegtr
                                Posted by Bazyle on 10/04/2020 13:09:00:
                                Yes probably due to my poor Alloy welding though.
                                Steve.
                                #463741
                                Howard Lewis
                                  @howardlewis46836
                                  If you can find a use for the parent metal, it is raw material, not scrap.
                                  It is only scrap when it is either too small to hold, or blue and curly!
                                  One of my show stand attractions, I hope, started life as an aluminium alloy candlestick. It stands alongside another made by a friend using a modified bicycle wheel.
                                  Let your imagination run riot! "It will come in handy one day"
                                  #463759
                                  Lofty
                                    @lofty83899
                                    A Scrap conrod into a clock
                                    Conrod Clock
                                    Lofty
                                    #463887
                                    Nigel Graham 2
                                      @nigelgraham2
                                      Scrap? No. New to me.
                                      I cut the original motor-plinth from the back of my Harrison lathe cabinet as it made the machine stand a wasteful foot away from the wall, in a workshop already tight for space. The new 3ph motor, physically smaller than the 1ph motor it replaced, is on a frame above the headstock, where it's also clear of dust and dirt around the floor. I had to modify the guard to suit.
                                      I didn't throw the welded-steel box away, not with a lot of 5/8-, 1/2 and 1/8- inch plate on it, though it took a fair number of 4.5 inch cutting discs to dismantle.
                                      One of the thick bits is earmarked for my wagon con-rods, the thin bits have supplied material for the wagon and the workshop hoist. A small off-cut picked up from the floor became a washer for a bolt clamping work to an angle-plate.
                                      A manual winch I built for a cave-digging project on Mendip uses a fabricated PVC drum thrown out at work (a left-over from something), between hexagonal frames I welded (well, very-hot-glued) from old miniature-railway rails that looked as if they'd been dragged through a hedge backwards then left there – as they had, for a couple of years in fact.
                                      There's something satisfying in finding a tatty, heavily-rusted old steel bar or plate has decent steel inside it waiting to be let out and put to new use. As long as it's easier to machine than some old cable-drum tie-rods I have in stock.
                                      The only new-to-me items I've really had to abandon hope on, were a cast-iron sash-weight so hard it even defeated a heavy hacksawing machine at work, a bit of architectural cast-iron that was free-cutting but with blow-holes reminding me of a pikelet, and a half-shaft too hard even for a carbide tip.
                                      Actually I tell a lie… I recall now the cast-iron pikelet was useless for a piston but fine for the heavy inner part of the lid on my steam-wagon's vertical ' stoking-shoot ', as the original was described.
                                      #463892
                                      Steviegtr
                                        @steviegtr
                                        Posted by Nigel Graham 2 on 11/04/2020 00:23:13:
                                        Oh my god & I thought I was bad. The steel stock holder is never going to make a profit out of you. wink
                                        Steve.
                                        #463902
                                        Paul Lousick
                                          @paullousick59116
                                          No such thing as scrap. Instead a valuable source of raw material. Unless it is too small to hold in a vice or lathe chuck. Its only after you throw it out that you realise a use for it.
                                          Paul.
                                          #463922
                                          Nicholas Farr
                                            @nicholasfarr14254
                                            Hi, well I like things made from "scrap" however, scrap is really something that cannot be reused in the form it is in and has to be reprocess, i.e. for any metal means melting it down. I really prefer the term reuse and I do it quite a lot. In my day jobs that I've had, just about everything that I've made used new material and this became less of a challenge over the years, as it was more to do with experience and routine. Making useful things from discarded items is much more of a challenge, because some things just don't work, so you have to think about it more and do work arounds. The compass shown below was made with all used materials from many different items, but with the exception of a 15 screws a short piece of S/S TIG welding wire and the level and some Danish Oil on the stand, although I have had the level kicking about for 40 odd years, the new screws I had to use, because I didn't have those sizes in used ones, but again they were all old stock.
                                            These candlesticks however, are completely made from used material, nothing new except a drop of thread locking compound on one item on both of them.
                                            Regards Nick.
                                            P.S. I like your clock Lofty.
                                            Edited By Nicholas Farr on 11/04/2020 09:36:11
