Water softness for copper boilers
Home › Forums › Locomotives › Water softness for copper boilers
  • #235614
    Ron Hancock
      @ronhancock63652
      Hi just finished building my Black 5 now ready to run it.
      I live in a hard water area so wondering if water softener salt would help.
      I have seen it advertised on eBay 25 kg bags would this work or is it better just to add white vinegar.
      I have also heard after running fill with cola will also clean.
      any info would be great full please
      ron
      #1517
      Ron Hancock
        @ronhancock63652
        #235616
          Get some proper water treatment which will help stop scale forming . The "TC" is the one for copper boilers
          #235617
          Ron Hancock
            @ronhancock63652
            Is it just caller TC sorry I am a novice
            Ron
            #235618
              Click on the bold water treatment in my post above and it will take you to as seller of "Multitreat TC"
              #235647
              Phil Whitley
                @philwhitley94135
                Use filtered rainwater, about as soft as you can get, and ever so slightly acid.
                #235658
                julian atkins
                  @julianatkins58923
                  Hi Ron,
                  Dont worry at the moment.
                  I will do a search online re your water quality for your area. I am quite sure you wont have the problems in parts of the south of england with hard water, which I was used to for many years.
                  Cheers,
                  Julian
                  #235667
                  DMB
                    @dmb
                    Yes Julian, Brighton’s water is very hard – pumped out of South Downs having filtered through the chalk hills. Tastes better than London’s regurgitated sewage.
                    John.
                    #235740
                    John Fielding
                      @johnfielding34086
                      Hi Ron,
                      As luck would have it I was reading some old ME magazines last night and there is a very good article on this subject.
                      Take a look at ME Vol 209, No 4438, 7-20 September 2012 for an article by Brian Baker called "Water Water". Everything you have always wanted to know, but where too scared to ask!
                      If you can't locate a copy then I can scan and send if you PM me with your email address.
                      #235744
                      Roderick Jenkins
                        @roderickjenkins93242
                        Posted by Ron Hancock on 21/04/2016 17:49:47:
                        Just to clear up any possible misconception: Water softener salt (normal NaCl) is used to regenerate an ion-exchange water softening system as often fitted to e.g. dishwashers. It is not added directly to the water to soften it.
                        HTH,
                        Rod
                        #235751
                        Bob Brown 1
                          @bobbrown1
                          While on this subject would reverse osmosis filter work?
                          #236196
                          Ron Hancock
                            @ronhancock63652
                            Failed to steam again Sunday the screw fitting that goes into tube plate started leaking. I had sealed with Loctite worked fine at home but second steam at the club it failed. I could not beleive how it failed after steaming so well at home.
                            Back to drawing board try again
                            Ron
                            #236201
                              Try boss white. Cheap as chips from B&Q.
                              "Boss White Jointing Compound is a non-toxic compound for sealing threaded joints on non-drinking water pipes. Suitable for hot and cold water and low pressure steam up to 7 bar."
                              OK, that's only 100psi, but its what LBSC always used.
                              Ron Hancock
                                @ronhancock63652
                                Thank you Neil I will get some tomorrow and try it
                                Ron
                              Home › Forums › Locomotives › Topics
