Variable Speed Drive.
Home › Forums › General Questions › Variable Speed Drive.
  • #22264
    DAVID HOWORTH
      @davidhoworth40264
      #100907
      DAVID HOWORTH
        @davidhoworth40264
        Dear Members,could someone inform me as whose variable speed drive is fitted and used on the Clarke CMD10 mico milling machine,as I wish to purchase something very similar in performance for a project I am working on at the moment.I would appreciate any advice/asisstance with the matter above.
        #100908
        John Stevenson 1
          @johnstevenson1
          Possibly a proprietary Chinese one or a KB drive from the States, both are DC drives and very similar.
          #100920
          DAVID HOWORTH
            @davidhoworth40264
            Hello John,thanks for your suggestions I will attempt to bring up some websites to have a look at, and see if they will fit in with the project.
            #100939
            Bazyle
              @bazyle
              You want to look at the threads on Chinese machines that have none 'pop' and find the suggested replacements.
              #100942
              Andyf
                @andyf
                I would suggest a KB Electronics drive. I fitted one to drive a 2hp DC motor (complete overkill on power, but the broken running machine it came from was £15) on my old milling machine. It has been very satisfactory. The model I used was the KBIC 240, good for 2hp but perfectly OK for smaller DC motors in the 180VDC or so range, if the appropriate "horsepower resistor" is fitted.
                Received wisdom is that KB boards are better than Chinese ones.
                Manual for the KBIC series is here, with details of the variants on page 8 and the horsepower resistors on page 9.
                Details of suppliers can by found by clicking "international" at the top right of this page; when asked what country, specify England rather than UK, if that's where you are.
                Usual disclaimer. Just a satisfied user.
                Andy
                #100968
                DAVID HOWORTH
                  @davidhoworth40264
                  Thank you Bazyle and Andyf for your inputs to my question,I have taken on board all suggestions and will be checking them out in due course.
                  Again, thanks everyone for your replies and suggestions.
