Universal bender
Universal bender
Home Forums General Questions Universal bender
  • #196517
    dcosta
      @dcosta
      Hello all,
      Does anyone know if I can make a hook like the one in the picture with the Universal bender in **arceurotrade** ?
      Diameters are 10mm and 25mm.
      Material stainless steel 3mm.
      Thanks in advance
      Dias Costa
      Edited By dcosta on 11/07/2015 23:17:27
      #23977
      dcosta
        @dcosta
        #196522
        Boiler Bri
          @boilerbri
          You will struggle to bend 3mm stainless to such a small diameter cold. You will most likely have to heat it up. If you can, make a small peg frame and try to bend I round that first. 100 x100 x10mm plate with a central pin threaded into it. Another pin, say 10 mm away to hold one end of the bar. Heat the bar then try pulling,wrapping the bar around the pin. You are going to have a tough time of it though.
          #196539
          Ady1
            @ady1
            We had a chat about the sort of thing you are after a while back
            cz metal bender
            It will deal with what you are after quite easily
            Chronos have them
            There is also a more expensive one
            Edited By Ady1 on 12/07/2015 11:30:38
            #200947
            dcosta
              @dcosta
              Hello all,
              Thank you for your help and ideas.
              I bought the bender from ArcEuroTrade ***HERE*** .
              I'm satisfied and already made a bunch of hooks. I had to make some more pins for the needed dimensions and they worked fine. See ***HERE*** please.
              Dias Costa
              #201075
              clogs
                @clogs
                Hi all, sorry to take the fun out of it…..this sort of thing is already available in IKEA and prob BQ…..
                Clogs
