Tool use explained.
Tool use explained.
Home Forums Workshop Tools and Tooling Tool use explained.
  • #200081
    Nick_G
      @nick_g
      This was sent to me by a friend of mine. Please feel free to add additional ones more relevant to model engineering. My fave is the engine hoist one. smiley
      Tools explained.
      DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it
      smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
      WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also
      removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, ‘Oh sh–!’
      SKILL SAW: A portable cutting tool used to make studs too short.
      PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
      BELT SANDER: An electric sanding tool commonly used to
      convert minor touch-up jobs into major refinishing jobs.
      HACKSAW: One of a family of cutting tools built on the Ouija board principle… It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
      VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also
      be used to transfer intense welding heat to the palm of your hand.
      OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
      TABLE SAW: A large stationary power tool commonly used to
      launch wood projectiles for testing wall integrity. May also have value in quickly removing various fingers and thumbs.
      HYDRAULIC FLOOR JACK: Used for lowering an automobile to the
      ground after you have installed your new brake shoes , trapping the jack handle firmly under the bumper.
      BAND SAW: A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
      TWO-TON ENGINE HOIST: A tool for testing the maximum tensile
      strength of everything you forgot to disconnect.
      #17801
      Nick_G
        @nick_g
        #200082
        Nick_G
          @nick_g
          PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as
          the name implies, to strip out Phillips screw heads.
          STRAIGHT SCREWDRIVER: A tool for opening paint cans.
          Sometimes used to convert common slotted screws into non removable screws and butchering your palms.
          PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50p part
          HOSE CUTTER: A tool used to make hoses too short.
          HAMMER: Originally employed as a weapon of war, the hammer
          nowadays is used as a kind of divining rod to locate the most expensive parts adjacent to the object we are trying to
          hit
          UTILITY KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records,
          liquids in plastic bottles, collector magazines, refund
          checks, and rubber or plastic parts. Especially useful for
          slicing work clothes, but only while in use.
          #200084
          Rainbows
            @rainbows
            I think you could make this a book if you get a long enough list
            #200097
            Gas_mantle.
              @gas_mantle
              Here's my few :-
              Magnetic stands – these are used primarily to support accurate measuring equipment. Contrary to popular belief the small cheap ones are more accurate as instead of taking one reading they allow the user to workout the average of 6 different readings all taken from exactly the same setting and positioning.
              Taps – Thread cutting devices designed to cut threads exactly 9* out of parallel, when buying taps it is advisable to buy matching dies from the same manufacturer as these will also cut 9* out to ensure a good fit.
              Protective eyewear – Properly known as damage transfer devices. These allow people who would normally wear corrective spectacles to wear special non corrective lenses, this ensures that any damage that would have occurred to the eyes is transferred to either the workpiece or the hands through the inability to see what one is doing.
              Metric micrometer – A simple threaded device that in skilled hands allows the operator to machine a part 0.5 mm too large or too small to within 0.01 mm accuracy.
              Parting off tools – These are made by toolmaking companies to attempt to replace the humble hacksaw. They do indeed cut through metal but break far more often than hacksaw blades, cost more to replace, and require accurate setting up that takes precisely 3.7 times longer to cut through 10mm steel than it would with a hacksaw.
              Micrometer blue – Sometimes referred to as 'Engineers blue' this is a vivid blue dye used to confirm your suspicions that the piece of metal you are scraping and filing away is the very piece that needs to remain in situ.
              #200099
                Hoary old chestnut alert!
                nigel jones 5
                  @nigeljones5
                  T'Ommer – hand held device used to rectify all manner of issues. Size is proportional to output. May be used by ladies but typically with less desirable results.
                  #200116
                  V8Eng
                    @v8eng
                    Posted by fizzy on 12/08/2015 10:38:43:
                    When I nod me Ed Son, you Hit it.crying 2
                    Edited By V8Eng on 12/08/2015 10:51:17
                    #200124
                    chris bond 1
                      @chrisbond1
                      Lathe accessories and essential engineering tools in general == items designed specifically to extract the money out of your wallet!
                      #200162
                      mark costello 1
                        @markcostello1
                        Wallet- something designed to never be full enough, and to be forgotten when going to car boot sales insuring many deals being made to disappear next week.
