Tom Senior M1 mill
Tom Senior M1 mill
Home › Forums › Beginners questions › Tom Senior M1 mill
  • #9969
    Peter Simpson 1
      @petersimpson1
      #440412
      Peter Simpson 1
        @petersimpson1
        Does the table on an M1 mill, power drive in both directions ? If not do you have to rewind the table at each cut ?????
        #440413
        not done it yet
          @notdoneityet
          Forgive me for asking what is likely very obvious, but how else would you get the table back to the pre-cutting position (other than by winding manually) if the power feed only operated in one direction and how would you avoid climb milling if the machine only power-feeds in one direction?
          #440414
          Oldiron
            @oldiron
            See here **LINK**
            Hope it helps
            regards
            #440415
            Andy Carruthers
              @andycarruthers33275
              Hi Peter,
              Assuming your Mill does not have the S Type head with independent motor then X axis power drive is right to left only
              With S Type head and VFD to main drive the X axis can be reversed as well as normal left to right travel
              #440418
              Peter Simpson 1
                @petersimpson1
                Andy thanks for your reply, my mill does have the "S" type head. I will ensure that the main motor is driven by an inverter that I can drive backwards and forwards. "not done it yet" but will in the near future.
                #440419
                Andy Carruthers
                  Apologies, my last statement should have read …normal right to left travel
