Titanium bolts.
Titanium bolts.
Home › Forums › General Questions › Titanium bolts.
  • #816926
    Trevor Howley
      @trevorhowley19606
      Hi all , I’m looking for a good supplier of titanium nuts and bolts around 5 to 6mm diameter, any suggestions please.
      #816973
      Hollowpoint
        @hollowpoint
        AliExpress.
        But I’m sure someone will be along shortly to tell you that Chinese fasteners are unsafe.
        I’ve used them for years. 🤷🏼‍♂️
        #816981
        bernard towers
          @bernardtowers37738
          THats a bit like saying I want a bit of metal for turning. dont you need to know what they are going to be used for so you can buy the right grade???
          #817095
          Trevor Howley
            @trevorhowley19606
            I’ll take a look on Ali express,cheers .
            #817170
            Old School
              @oldschool
              GWR Fasteners have them in the sizes you want.
              #817172
              Vic
                @vic
                I bought a variety of Titanium Cap Head Socket screws many years ago up to M8 with very nice reduced head. I can’t remember the specific supplier, but, I believe it was one that supplies bolts for Motorcycles etc, so that may aid in any future search terms?
                Edit: I did buy a couple of M4 or M5 from RS components. Not sure if they still sell them?
                #817183
                Trevor Howley
                  @trevorhowley19606
                  Thank you for replies ,will try GWR.
                  #817204
                  Trevor Howley
                    @trevorhowley19606
                    Thank you Old school , GWR have a good selection .
                    #817379
                    Involute Curve
                      @involutecurve
                      titan-x.com
                      #817492
                      old mart
                        @oldmart
                        You hopefully realise that titanium bolts are nowhere as strong as high tensile steel ones.
                        #817532
                        Trevor Howley
                          @trevorhowley19606
                          They are being used for joining ally parts for anodising .
                          #817545
                          bernard towers
                            @bernardtowers37738
                            I use 2mm titanium welding wire for that job.
                            #817593
                            Trevor Howley
                              @trevorhowley19606
                              The two parts ideally when joined for anodising stay joined ,hence the need for titanium bolts ,as I understand you can’t use stainless steel .
                              #817723
                              old mart
                                @oldmart
                                You can also get aluminium wire in different gauges which commercial platers use all the time when anodising. The used lengths are discarded after use as the surface of the wire will be non conductive. There are possible disadvantages of bolting components when processing. Chemicals can get trapped in the joint and leach out later spoiling the finish.
                                #817751
                                Trevor Howley
                                  @trevorhowley19606
                                  Oldmart, good point this is something I hadn’t thought about , thank you for the advice .
                                  #817754
                                  bernard towers
                                    @bernardtowers37738
                                    pros dont use all wire as the current is disconnected by the anodising process ,dont ask me how I know!!!!
                                    #818222
                                    old mart
                                      @oldmart
                                      Allow clearance in holes which are to be anodised, with sulphuric anodising holes will shrink by the thickness of the coating. A surface will grow because the substrate dissolves to make the aluminium oxide coating which is twice as thick as the aluminium used up in the process. So a coating 0.001″ thick raises the surface by 0.0005″ from its original level.
                                      In critical parts like aircraft applications there will be oversize taps specially made to compensate for the thickness of anodising and cadmium plating if the holes are not being masked off before surface treatment. The alternative chromic anodising is normally much thinner and very unlikely to require any compensation for thickness.
